Results 1 to 13 of 13
    Sep 2004
    Sorry, newbie question lang.
    I just bought an HP a6640d desktop. According to the specs sa HP website, DDR2 Dual Channel memory na siya, 800mhz, tapos with 2 memory banks, pero only 1 slot is occupied.
    2gigs lang kasi memory niya, tapos on-board pa yung video, so I plan on buying an additional 2 gigs of memory (para 4 gigs na siya) and a separate PCI-E video card.
    Problem is, bakit yung nakikita kong dual channel memory sa websites 2 sticks? Paano pa kakasya yun eh only one memory bank is available? Puwede ba pag-haluin yung dual and single channel memory modules? Baka kasi mali ang mabili ko, sayang lang ang pagod.
    Baka may PC techies dyan, patulong naman.
    Jan 2009
    You can't run dual-channel with just one stick of RAM. You'll need at least a pair of identical sticks to make it work. Otherwise, it's running in single channel mode only.
    a single stick will always be a single channel. don't be confused, any pair of identical ddr2 will give you dual channel. as long as the mobo supports dual channel. dual channel kit are just marketing hype.
    Nov 2007
    search mo muna sa google baka di supported ng board mo yung 4 gig or ram
    Jan 2009
    Quote Originally Posted by aga_cruz View Post
    It supports it. (2 x 2GB)
    Sep 2004
    Thanks for the replies. Medyo nalito kasi ako sa terminology. My mobo (MSI MS-7525) can support dual channel, pero I guess since 1 stick lang nakasaksak, single channel mode nga lang siya.
    Jun 2006
    bili ka na lang ng isa pang 2Gb stick and it will switch to dual channel.
    if you're using a 32-bit OS, you'll only see 3.5gb though.
    just make sure that the RAS/CAS timings nung additional memory module na bibilhin mo ay pareho nung naka-install sa desktop mo. you'll be able to quickly see yung RAS/CAS timings using cpu-z
    try to download the free utility CPU-Z
    Makikita ninyo ang slots available and slots used in the utility and what type ang memory so you can state that when buying another RAM
    Sep 2004
    Ngek. I researched a little more on the practicality of having 4gigs of RAM on a 32-bit OS. (Am currently using 32-bit Vista sa house). Maximum addressable memory space pala niya is only 4gigs, tapos shared pa with other add-on cards with memory (vid/sound cards, etc), kaya sometimes 3.2gigs na lang ang available.
    Hindi rin daw better alternative ang pag-upgrade to 64-bit OS, since medyo buggy pa ang 64-bit Vista, and the lack of drivers to support both hardware and software.
    So I guess I'm better off buying a video card na lang muna.
    *Macmon: Thanks for the tip. I already downloaded that utility.
    Jan 2009
    Quote Originally Posted by Galactus View Post
    That's probably true if the year was 2007. I have Vista Ultimate x64 and never EVER had a problem with drivers, or bugs for that matter. And I'm into connecting a lot of stuff on my PC too (ie. digital camera, scanner, printer, Logitech wheel, iPod, Garmin eTrex (serial) and Nuvi (USB), smartphone and even a PCI cable-TV card. You'll be surprised how much driver support Vista x64 has now.
    Heck, this is even more rock-solid than the WinXP SP3 I had before this.
    Though, I admit that Vista is not the best OS in terms of efficiency. But since Windows 7 is promised to deliver what Vista didn't, I'm sticking to Vista x64 for now until Windows 7 becomes retail.
    same pala tayo bro.
    two 2GB ram ddr2 667 = 4GB pero 3.2 lang lumabas.
DDR2 Dual Channel Memory
