Results 201 to 210 of 954
- Mar 2013
- 6,160
May 18th, 2020 07:59 AM #201Whats a good compressed air cleaner duster for laptops/desktops.
Am looking for something portable/rechargeable and with good air pressure?
- Mar 2005
- 703
May 18th, 2020 08:01 PM #203
Eyeing Speck also, sa picture ko pa lang nakita eh pero sana slim pa din kahit installed na.
Ayan nag dalawang isip ako mag lagay ng case hehe tsaka walang vent / holes underneath yung MBA paano kaya singawan neto.
OC lang talaga ako siguro kase bago, lilipas din ito pero one thing for sure takaw gasgas where you got your slip cover? Para nga din pag nilagay sa bag.
May 18th, 2020 09:04 PM #204
When transporting the laptop without a bag, good to have a sleeve with sufficient protection:
Tapos best to use a bag with a separate laptop compartment with padding. If wala, then use a sleeve like above before putting it in the bag to avoid scratches.
Sent from my SM-N970F using TapatalkLast edited by jut703; May 18th, 2020 at 09:40 PM.
- Jan 2018
- 844
May 19th, 2020 06:27 PM #205
- Nov 2009
- 3,509
May 19th, 2020 07:59 PM #206I use the polyster version of case logic plus a "telon" in between the kb and screen to avoid scratching the inside surface.
May 19th, 2020 08:27 PM #207
Do not use palm rest or keycap covers on a Mac notebook with a Retina display - Apple Support
I also use a keyboard cover (to mitigate the crappy butterfly keyboard feel) but the article above advises against it because it can damage the AR coating of the screen.
- Nov 2009
- 3,509
May 19th, 2020 08:51 PM #208^I cover cam of my laptaps with paper and scotch tape as safety precaution. Even during zoom meetings i'd turn vid off and use profile pic instead.
My previous biz loptops got scratches on the LCD surface esp the one i used to leave inside the vehicle.
edit: the cover i'm referring to is just a telon like felt paper that i buy at textile shops then cut size that fits the screen area not the chicklet-type kb cover.Last edited by 12vdc; May 19th, 2020 at 08:59 PM.
- Jan 2018
- 844
May 19th, 2020 11:43 PM #209I also used to have a keyboard cover on my macbook pro to prevent dust from getting into the crevices which is the primary cause of the butterfly switch issues. But it started marking the screen and I just decided to stop using the cover. I now opt to clean the keyboard with compressed air.
May 20th, 2020 01:33 AM #210
Did it damage your screen though? Mine also marks with the keyboard cover but natatanggal naman with a microfiber cloth. Recently I've been removing the cover when not in use but it's kind of a hassle. Not sure if it really has a long term impact if you have a keyboaed cover all the time.
薄利多销 or what was it they called it?
China cars
