Results 1 to 10 of 35
May 26th, 2007 05:47 AM #1
help peeps...we're finally moving to a new home and would set up my internet tomorrow (so i need help asap.herherhehr)
the house has a main floor, 3 bedrooms and a big basement...
so what wireless router do i need? i need something basic that can go through drywalls with ease....
do i need a range expander(?) or booster?
wireless G? wireless N? do i need them?
im looking at second hand items in craigslist.org but im willing to cinsider brand new ones too (limited budget)..herhehrer
thanks!
EDIT: my laptop's specs says....802.11 a/b/g ...so does it mean i cant use an N?
Driver/PasaHERO
- 1,310
May 26th, 2007 08:35 AM #2we're using Linksys router-G(forgot the model) d2 sa house ng sis-in-law ko sa CA, although 1 floor lang bahay nila, tumatagos nman sa walls, excellent ang connection kahit mejo malayo na at may harang na pader, kahit nakaupo sa banyo :D
Tsikot Member Rank 4
- Jun 2006
- 2,605
May 26th, 2007 12:38 PM #3+1 on the linksys, ok din netgear. You can use N but it will be limited to G speeds (54mbps).
Ask ko din, what wireless router can I use to pass through cement walls? House is mainly cement, buhos. I'm currently using an ediman wireless g router. Signal can't reach the 2nd floor. My room is right on top of the router and I still can't get a signal. Will a N help?
May nakagamit na ba ng Coregora? Its half the price of other N routers and made in Japan daw.
May 26th, 2007 12:58 PM #4
Glenn you could get a Wireless N router and in order to fully maximize it, you'd need to get a PCMCIA or USB N WiFi card. Sulit talaga siya. You get faster speeds on the network (note, network not internet) and a farther range as compared to a G or lower WiFi Router.
May 26th, 2007 05:02 PM #7
Linksys ang gamit nami sa office.
:toma: 2945Last edited by j_avonni; May 26th, 2007 at 05:12 PM.
May 26th, 2007 05:32 PM #8
unless you plan on upgrading to wireless n receivers anytime soon, a wireless g router would be the best bang for the buck. and the wireless gods are drafting another revision to the recently standardized n anyway.
check out linksys wrt54gL. it's linux based kaya maraming 3rd party firmware available to enhance the router's capabilities. been using one for almost 2 years problem free. good signal strength even through floors and walls over a 200sqm area. just set the router on the approx. center of the house and you're all set.
make sure you get the gl model and not the plain g or the gc. the g has horrible reviews (see tomshardware, etc.) and the gc is best used on small areas such as dorm or condo units.
May 26th, 2007 05:37 PM #9
May 26th, 2007 05:44 PM #10
Exactly. I highly recommend the WRT54GL, with dd-wrt installed on it. If the signal is strong enough (highly unlikely), you can buy an a bigger antenna, or buy a cheap WRT54G to extend the signal. Most likely, however, you won't have to do more than buy that first router.
Don't waste your money on N.
Looks like TGPH silently edited the article and removed the entry for Velocita Motors/Ferrari.
Car Sales Data (2024)
