Results 1 to 10 of 10
    Jun 2006
    Whats a good bar code printer and where can I buy?
    Barcodes can be printed even from a standard injket or laser printer... though their limitation is the longevity of the said barcodes.
    For a more durable barcode sticker, you should purchase a thermal printer. I'll try to find out the brand that we use here in the office.
    Dec 2003
    ito gamit ng depot namin, Zebra Z4MPlus industrial grade thermal barcode printer. super heavy duty ito just like those used by big malls. medyo may kamahalan lang nga * 90+k, 2 years ago if i remember correctly. problem is i have no idea where we got it, kapatid ko kasi bahala dun.
    Jan 2003
    There is no "best" bar code printer. It depends on several factors -
    1. How will your bar codes be read - by gun or scanner?
    2. Will the labels be applied flat or on shaped objects?
    3. What are the sizes of your labels?
    4. How often will you be printing?
    5. How long do you need the bar codes to last on the label?
    As mazdamazda pointed out, you can print barcodes right out of the standad inkjet or laser printer, or you can opt for high-end high-speed models. But if your application does not require high resolution, long-lasting prints, then buying a high-end model may be overkill.
    Just my 2 cents.
    Jun 2006
    Quote Originally Posted by architect View Post
    Just my 2 cents.
    1. By hand held scanner, Symbol brand the one used on most POS/cash register machines.
    2. Flat labels, for price tag on dry goods.
    3. Normal sticker price tag size similar to the size used by most department stores.
    4. Not sure, nautusan lang maghanap. Not really my department.
    5. Don't know I guess a few months to a year on the outside.
    How do you print barcodes from a laser or inkjet printer?
    Feb 2005
    we use the Datamax I-4208 and Seagull Bartender as the software to print labels.
    Feb 2005
    Quote Originally Posted by userfriendly View Post
    you can download fonts that has the capability to print barcodes.
    you should also know the barcode format that you will be using (Code 39, Code 128, EAN/128...etc)
    Jan 2003
    Sorry for the late response. The frequency of printing determines the durability required for the printer so you may want to find out.
    If the dry goods are sold rather quickly then you don't need the labels to last that long.
    And as cOzee stated, you can download bar code fonts but you need to know the format you are using, although some software allows the use of custom formats.
    if you have CorelDraw, it has an included software that let's you print barcodes.
    Mar 2004
    Zebra is the best brand available locally. Datamax comes close.
bar code printer
