i have a asus laptop. more than 1 year na siya. kaso ngyon ayaw na umandar yong ibang keys..
ano pede ko gawin? pwede ba ito diy o dapat pa repair ko na.
san ba maganda pa repair?
As far as I know, Asus gives 2 or 3 year warranties for their laptops so you might want to check out if you are still covered.
If you are comfortable with opening up a laptop chasis, you can take off the plate cover or bezel of your keyboard to expose the keys and check if the ribbon is connected securely. You can also check if the membrane underneath is properly aligned to the contacts. There should be a number of video tutprials available on the net if you are willing to go the DIY route.
thanks digitalron!
will check out the warranty, ang alm ko kasi usually 1 yr lang.
in case out of warranty na unit mo and you dont want to open your laptop by yourself, try hottoyzph.com. Had them replace a lcd screen for a toshiba laptop 2 years ago and its still working fine. Cant remmeber how much they charged but it was a whole lot cheaper than what Toshiba wanted.
okba ang sst laptop repair? 3500ang quote saakin kaya lang ordr pa daw yng keyboard
