Results 1 to 9 of 9
May 28th, 2004 01:35 PM #1
what to do?
nag-Application close ang phone ng friend ko.
baka may alam kayong solution.
please help.
di pa naman daw puno ang memory ng phone, and maluwag rin sa memory card.
TIA
May 28th, 2004 01:38 PM #2
may nilagay ba siya na mga ibang appliation dun?. minsan kasi sa mga apps yan eh pag may sira
May 28th, 2004 02:01 PM #3
Steve,
Since the file is in wav format, it needs a player application to make it play. Hindi kasi native ng Nokia yung wav, amr dapat.
Anyway, since ginawa mong ringtone and someone calls, the said application will load and play the file.
The problem is when someone calls and you answer, naka-tengga pa rin yung app. why? because the tone youre loading is 900kb large!
Isipin mo pare ang processors ng handset napaka bagal. i dont even think kasing bilis sila ng sinaunang PalmPilots.
kaya advise ko sayo pare, cut down on the size or try using nokia's proprietary .amr format ;)
May 28th, 2004 02:23 PM #4Originally posted by tebs
what to do?
please help.
TIA
the first time, sabi sa semicon, i just need to upgrade my software daw. so pina-upgrade ko. but after about 4 months, gano'n na naman problem. the last time kaya dinala ko na uli sa semicon is, ayaw na mag-on. "some files may be corrupted" daw.
one friend told me yan daw talaga sakit ng 3650.
tell your friend - di siya nag-iisa...
May 28th, 2004 05:32 PM #5
teka, bago ang lahat, saan lumalabas yung application close? sa power-up pa lang ba? o while doing something?
kung sa power-on pa lang, nothing you can do, except to initially as what was suggested here... which is to do a reset (or restore factory settings..) pag hindi gumana, you may need to have your unit reformatted or reflashed.
May 28th, 2004 06:05 PM #6
Kung install/unistall ng apps thru memory card, yun lang ang reformat. Backup all existing files into a computer or another memory card.
Pero kung sa phone memory ang ginagamit sa install/uninstall ng apps, buong phone ang reformat. Kahit na software update or upgrade pa ang gawin, sa reformat din ang punta nyan. Corrupted na kasi ng registry files ng phone.
May 28th, 2004 11:05 PM #7
just be careful in uploading apps to your fone.. 1year na sa akin ang 3650 and dami ako apps na nilalagay pero ndi ko sinasabay sabay sila... wala pa namang nangyayari sa fon ko except sometimes sasabihin contact retailer pero a simple on off ng fon lang ang solution
May 29th, 2004 09:46 AM #8
sa start up pa lang, lumalabas na yung message.
pero napaayos na, tatanong ko pa kung pano ginawa. nawala daw lahat ng laman ng phone. so malamang nagformat na sila ng phone.
update ko na lang dito kung ano nangyari, for future reference ng mga tsikoteers
May 30th, 2004 10:33 PM #9
got my phone from semicon today. asked the csr kung bakit nagkakaproblema na gano'n. sabi, baka daw may na-download na file na corrupted, affected ang software.
in-upgrade lang nila system software, and yes, i was informed all data in my phone memory will be lost. then, yun mga naka-backup na file sa mmc ko, di ko pwede i-restore, baka daw may file doon na corrupted, masira na naman.
therefore, it's not enough na sa mmc lang naka-backup mga phone nbrs. nothing beats the ever reliable phonebook. sa manual pa rin.
sayang space impact ko, at saka yun mga ringtones and pictures.
It says CVT daw. For better FC siguro.
Mitsubishi Xforce
