Results 1 to 10 of 10
    Sep 2014
    I have 2 mirror type dash cams, the images taken by the rear cameras of both dash cams are vertically flipped. no matter the car is moving forwards or backwards.
    Is this normal in mirror type dash cams?
    Does the rear camera of your dash cam also create a flipped image?
    I tried to upload an screenshot, but the upload option did not work.
    Last edited by bigT; May 8th, 2019 at 12:06 PM. Reason: Add the note about the upload option.
    Jan 2009
    Just to be clear, when you say "flipped", does the monitor show the image to be upside down or left becoming right?
    Sep 2005
    pag may words hindi mo mabasa?
    Sep 2014
    Left becomes right.
    Jan 2009
    My observation with my own dashcam is that, the live view is mirrored. So left objects in relation to your vehicle appear on the left side of the screen as you view it using the built-in LCD display.
    However, when playing back the file on an external device (PC, mobile phone), the image orientation is correct. The object to the left of your vehicle will appear on the right of your screen upon playback.... just as how the camera sees it.
    This means that the mirroring only happens on the dashcam's live view display.
    Sep 2014
    I have been trying to upload a screeshot, but I can’t. I have posted a similar question in another forum, please open the link
    Image taken by rear camera flipped | DashCamTalk
    the screenshot was from a video taken by the rear camera of my dash cam, the car was behind my car and was moving in the same direction as mine. You can see the plate number was vertically flipped.
    Jan 2009
    Upload the image on Imgur and post the BBCode here.
    But anyway, if you haven't done so, you'll have to check the camera settings if it has the option to flip the rear camera image. Otherwise, there's nothing much that can be done other than use a video editing tool or player like VLC to flip it back to normal once the file has been extracted.
    Worst case, you would only have to do this if you need the footage for something (ie. after an accident or reviewing a notable event).
    Mar 2004
    It's quite possible he installed the dashcam upside down ...
    Jan 2009
    I highly doubt it. If it was, the image on the screen and the output file will also be upside down.
    Happened to two of my dashcams with rear cameras. There is a setting in the dashcam that solves this issue. Explore mo lang.
Image taken by rear camera of dash cam is flipped
