Results 1 to 8 of 8
March 2nd, 2012 10:49 PM #1
Here's my setup
[Modem] === [Wifi router 1] <--- wireless / bridge mode ---> [wifi router 2] === cable === [wifi router 3]
My problem is, when I connect my devices wirelessly to router 2, they can no longer connect to router 3 and vice versa.
There's no problem connecting to router 1.
When a device connects to router 2 and I go to the area near router 3 and it connects to it, that device will be given an IP of 169.xxx.xxx.xxx
What could be wrong with the setup.
Btw, router 3 is setup as wireless access point.Signature
- Jan 2011
- 445
March 3rd, 2012 12:42 AM #2Can you post the ip configuration of all the router? Also, can you make sure that all of them are interconnected?
- Mar 2004
- 33
March 3rd, 2012 09:13 AM #4
what's ip config? eto ba yun?
router 1 192.168.1.2
router 2 192.168.1.3
router 3 192.168.1.4
naka on dhcp ng router 1, off sa router 2 & 3.Signature
- Nov 2002
- 1,326
March 4th, 2012 03:02 AM #5Originally Posted by boybi
Pag connect mo so rouer 2, then lipat ka sa area na connect to router3, the ip address you get is 169.xxx.xxx.xxx?
Pag connect mo to router 3, then lipat ka sa area na connect to router2, the ip address you get is 169.xxx.xxx.xxx?
SSID of all 3 routers the same? Wpa or wep password of 3 routers also the same?
Router2 and router3 are both set up as access points?
Dhcp of router3 should be off or another work around is that dhcp of router3 can be on, but the address pool of router3 and router1 should not clash, then set default gateway for both router1 and router3 to be ip address of router1, and dhcp addrress pool of router1 and router3 should also be within the same subnet...
March 7th, 2012 12:58 PM #6
pag connect sa router 2 then lipat sa router 3, 169.xxx.xxx.xxx ang IP
pero pag balik ulit sa router 2, ok naman.
magka iba and SSID ng 3 routers. same passwords.
router 2 & 3 set as AP, pero naka bridge ang router 2 sa router 1 since wireless ang connection nila.
tried to turn on DHCP of router 2, with different address pool than router 1. naging ok, but this morning biglang naging 169.xxx.xxx.xxx yung iphone ko when I woke up. weird.Signature
March 7th, 2012 01:01 PM #7
March 7th, 2012 01:15 PM #8
Yes, rebooting the router works. Even before I did not turn on the DHCP of router 2, if I'll reboot it, I'll be able to connect to it.
Signature
Try mo sa Hino Parts Specialist sa may Grace Park, Caloocan. Search mo nalang sa google maps or...
Hino 300 Series Light Truck (Dutro)
