Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
    we have used both vulca seal and epoxy.
    and our opinion is,
    "either works. but we think vulca seal is easier to apply, and is cheaper."
    Use Polyurethane...the ultimate multipurpose sealant/adhesive.
    Dec 2009
    I had my gutters, sanipa & drain pipes changed just last November. Doc is right that it would look look like an eyesore, but mine turned out OK since the house is painted white & blue gray. If it were painted a darker color, wouldn’t look good. Gutters are actually the headache in house maintenance, so best to go stainless. I also changed my post lights to stainless steel to match the stainless steel gutter.
    stainless is good, theres no need to paint it
    Sent from my ASUS Chromebook C202SA using Tapatalk
    Or go gutterless. We've long transferred em to the ground...open trenches covered by plastic kennel pallets & stones....to the delight of gutterphobic homeowners. Zero leaks, No collateral risks, hassle-free, super low maintenance & ultra efficient. They do everything gutters do....but way better. One big thing less to worry about.
    Sep 2014
    My house can't be gutterless, during heavy rain water from the roof will pour into neighbour's house.
    Sep 2014
    and our opinion is,
    What I worry about using epoxy is
    1. When epoxy sets, it is hard and not flexible, I doubt will any movement of the gutter will spoil the bonding, and break the epoxy from the gutter surface.
    2. When gutter exposes to sunlight, metal and epoxy expand in different rate, the difference in expansion will create a force to crack the epoxy and tear the epoxy from the metal.
    Vulca Seal when set is still slightly flexible.
    Quote Originally Posted by bigT View Post
    You can install a 'rainstop' at the end of your roof to guide the flow vertically onto the trenches. Sample of what we usually do in pics below.
    chains, as guides?
    ...paint 'em your choice of color...
    chains, as guides?
    Works for spouts....but to have em would mean gutters, too.[emoji4]
    oo nga pala...
Aluminium Gutter/Pre painted steel gutter
