Results 1 to 9 of 9
- Jan 2007
- 4,459
June 7th, 2010 04:47 PM #2
The first thing to do is stop working on the disk. Mount it as a secondary drive and then perform a recovery using disk-recovery tools. A lot of the tools in the web are available for purchase, though you might find a freeware. You may take a look here:
http://www.freebyte.com/filediskutils/#datarecovery
June 8th, 2010 12:51 AM #3
Try searching this in google: "getdataback". So far, we've successfully recovered crashed HDD and accidental re-formats.
June 8th, 2010 09:09 AM #4
GetDataBack is what we also uses and it can even retrieve data even how many times you reformat the disk.
- Jan 2007
- 4,459
June 9th, 2010 10:04 PM #5Thanks guys. Trying GetDataBack now. I had to go back to step 1. It has been 2 days already, ang parang di na nagrespond ung application. Ganon ba talaga?
BTW, my external HDD is 300GB.
June 9th, 2010 10:48 PM #6
Recovery will be faster if....
If you have a Desktop PC, remove the 300GB from the USB enclosure and install it internally on the PC.
You would also need 2nd Hard Disk to write recovered files.Last edited by Mile2; June 9th, 2010 at 10:51 PM.
- Sep 2003
- 102
June 12th, 2010 09:27 AM #7you can also try testdisk.
I used this once when i had to recover a deleted partition.
testdisk was able to recover it.
hope this helps.
- Jan 2007
- 4,459
June 14th, 2010 01:57 PM #8Guys san kaya pwede magpagawa nalang ng ganito (restoration/recovery)? Hassle kasi eh.
June 14th, 2010 03:01 PM #9
I can do it.
GetDataBack is what I use, kapag may kailangan akong i-restore/retrieve deleted format files.
Traffic!
