Page 1 of 2 12 LastLast
Results 1 to 10 of 861
    Quote Originally Posted by aga_cruz View Post
    langya sa tulin ba sana pag labas ng bagong pregio crdi na din ang makina heheehehehe
    sa temp parang wlang naka install na thermo ang lamig
    Uyy, me lalabas bang bagong Pregio? Baka yan na ang van for us, kasi I can't both afford the Starex VGT and the Super Grandia (which is also underpowered at 105HP), so baka good option yang Pregio!
    Kelan kaya lalabas yan?
    nakapag 140km/h ako sa katipunan sa isuzu trooper 4jx1 ko. 2 am, 8 pax on board all windows down pati skyroof pero naka on ang AC. no problemo.
    Dec 2008
    140kph-montero sport gls se on 4H 4WD MODE sa NLEX heavy rains di ko namalayan nasa 140 na pala
    165 kph -montero sport gls se on 2H sa SCTEX
    Dec 2008
    Quote Originally Posted by toronegro View Post
    4H on NLEX????
    Better have your front differential and transfer case checked!
    The Montero is a part-time 4x4, just like most hard-core offroad vehicles. But unlike the high end Land Cruisers or Land Rovers, it has no center differential.
    Thus, the 4H and 4L is only designed to be run on mud or slippery surfaces. Running it on a pavement, even when wet, at 4H will cause "binding". Prolonged us will break your front differential and/or transfer case.
    I suggest you read your manual again on how to properly use your vehicle.
    Dec 2008
    Quote Originally Posted by FWC View Post
    4H on NLEX????
    as i remember , montero sport is equipt with a super select 4wd system ,even at 100kph you can shift to 4h 4wd and i have tried that ..4h for a montero sport is a full time ,,you can use it on slippery surfaces like the paved road
    cheers
    Dec 2008
    on the place where i live ..when ever i caught with a heavy rains on the road i always tried my 4h and shifting it while its running at the speed of 80 to 100 kph and i dont have any problem
    quick guide sa super select 4wd. ewan ko lang kung parehas sa models sa pinas ito
    http://www.grupo-minicar.com/mitsubi...tero/ss4ii.htm
    Dec 2008
    Quote Originally Posted by jaymd View Post
    many thanks sir jaymd that is how my 4wd system works, thats why i am very confident using it
    cheers
    Dec 2008
    cheers
    Super select has nothing to do with it. It simply means that you can engage 4x4 without stopping when running fast on rough or slippery surfaces.
    Are we talking of the same local Montero model? The local model does not have full-time 4-wheel drive. The mere fact that it has 4H is an indication of that. That is why you have a selector lever or switch for 2H, 4H, or 4L. Pag full-time 4-wheel drive, walang kang selector for 2H kasi naka full-time ka na nga, eh. So you only have High or Low.
    The only reason your front differential or transfer case did not break is because you may be generally travelling in a straight line (as indicated by your 140 kph speed). But do it in a curve or zigzag road, and they will surely give.
    Anyway, just want to help. So it's your own look out if you won't take it.
    Dec 2008
    many thanks ,thats why were on this forum ,to learn and share .
    yeah!! its the local model 2h 4h 4hlc 4llc
    cheers
What is Your Fastest Speed using a Diesel Vehicle?
