Results 1 to 10 of 13
December 31st, 2005 09:43 PM #1
im planning to put a turbo on my stock 93 l200 , would that be ok ? kasi i dont know if i can trust the people in banawe eh sabi ni ok daw pero di ako sigurado i hope you guys can help me.
December 31st, 2005 11:05 PM #2
non-turbo engines can be turboed, but it's better to start instead by getting a stock turbo engine.
pero you could contact fusion r and autoplus and they'll give you options for this. hth.
January 1st, 2006 12:13 AM #3
ic thnx for the info i just got confused eh i read some threads , btw would a normal tachometer work for a diesel engine ? or meron bang special na kind of tach na para sa diesel lang ?
January 1st, 2006 12:20 AM #4
iba ata yung pinagkukunan nila ng signal for the tach compared to a gas one.
anyway, a guru i am not, so let's wait for their replies. busy ata with the new year stuff eh. :D
January 1st, 2006 03:16 PM #6
mas ok if you get the same kind gamit sa strada 4x4 turbo.. L200 sa iyo? kabit and forget na.
- Dec 2002
- 2,335
January 1st, 2006 04:09 PM #8
dba iba ang compression ratio and pistons ng Turbo sa non-turbo?
sabi sa'min di daw bolt on ang Turbo sa N/A na 4d56...is that true?
January 1st, 2006 05:10 PM #9
*garyq , kung sa injection pump can i still use ung normal na tach na nabibili sa banawe ?
- Jun 2004
- 476
January 1st, 2006 09:19 PM #10As far as I know the internals of a 4d56NA and a 4d56TD engines are different. You can install a turbo onto a 4d56NA but you may run the risk of "blowing" up the engine fairly quickly.
Xiaomi E-Car
