Results 1 to 7 of 7
    Dec 2002
    im a newbie hir..... :D :D :D
    tanung lang po,
    ok lang po ba kung d na diretso ang torsion bar ng suspension kc kita ko torsion bar ng sasakyan namin d na diretso medyo bended na...
    may effect po ba ito sa ride quality.......
    thanks :shock: :o :lol: 8)
    jun,
    Pano nabali iyon? Hehehe. Ang tindi mo naman. Pagkakaalam ko basta pantay ang magkabilang dulo (kahit nay konting kink or bend sa gitna) gagana pa rin iyan.
    I'm not sure if TB's are repairable pero do not use heat to repair them dahil hihina ang bakal.
    Teka, baka naman talagang may bend yung TB ng sasakyan mo. Ano bang sasakyan ang pinaguusapan natin dito?
    The torsion bars should be straight. If one is bent then it probably came into rude contact with something, check the ends of the bar where they are attached as you may find more damage.
    Torsion bars are actually your vehicles front springs, they are supposed to twist/torque as your suspension arms move. It being bent surely affects its "torquing" characteristics.
    I feel you should have this checked and repaired asap.
    Dec 2002
    d naman po nabali. bali may bend na sa gitna d na diretso. ang sasakyan po namin ay hi lander xtrm'99 model. duda ko nga po ay dahil sa shock kaya nagakaanun kc parang worn out na ung shock sobrang tagtag ang hirap pang kontrolin e kaka allign lang and balance nung tire
    ma affect din siguro ang caster yan.
    Quote Originally Posted by jun
    Kung bali yan, syempre bagsak ang suspension at di mo na magagamit ang Hi-lander.
    Well you've got to fix the problem, change both torsion bars, shocks and have the front end re-aligned.
    FYI - you can get 2" extra height from the front torsion bars w/o stiffening the ride if done right.
    Dec 2002
    salamat po sa mga reply......
    buti n lng andyan kau......
    magkano kaya abutin pag pnalitan ko torsion bars and shocks
torsion bar
