Results 1 to 9 of 9
March 20th, 2004 08:16 PM #1
Hi guys,
It's been a long time.
I have some questions that need some answers and advice if you dont mind?
Ride: 3door Pajero RHD Converted to LHD
1. After a checkup my mechanic told me that my Idler Arm, Left and Right Lower Ball Joints already had a play. My Question, is it necessary to replace those parts immediately? My plan is to replace those suspension parts together with the LHD Gearbox that im acquiring. Any effect if i dont replace the parts immediately and still continue driving the pajero? Will it do harm to other suspension parts? Any advice you can give, im planning to acquire an orig LHD gearbox sometime this May.
2. I already did replace lower left and right ball joints sometime around September using an orig 555 replacement ( i can guarantee that it's a genuine 555 because i bought it from a friend). Is that the normal lifespan of a replacement balljoint? How can i prolong the life of my suspension system? Im just using my ride in the city and i dont do offroading, i slow down especially when i encounter potholes... i do travel outside the city sometimes but it's not that rough.
hope you can answer all my questions...
thanks,
marwen
March 22nd, 2004 10:50 AM #2
1) Hindi naman rush yung pagpalit nitong mga ito. Mas maganda if you replace them after you replace the gearbox.
2) Kung walang problema, dapat balljoints would last years... even the 555 ones.
March 22nd, 2004 11:04 AM #3
Ang harm lang niyan kung wala na sa alignment gulong eh di uneven wear.
I suggest replace them all together with the gearbox para isang alignment and camber na lang. tipid sa labor.
Ball joints madalas lower nasisira pero dapat mga after 2 to 3 years depende sa dinadaanan mo araw araw.
March 22nd, 2004 02:21 PM #4
PK,
So okay lang kahit i byahe ko this holy week yung pajero without replacing the ball joint and idler arm.. ? Yung uneven wear ng tires lang ang consequence ko duon, right? How about the other suspension parts.. no effect ba talaga pag di ako nagpalit.. mga 3 hours na byahe ang tatakbuhin ko this holy week.
As frt said... mas tipid kasi sa labor pag sabay ko pinagawa lahat..... thanks...
March 22nd, 2004 02:23 PM #5
Wag mo na masyado isipin iyan.
Tsikot Member Rank 3
- Mar 2003
- 637
March 22nd, 2004 07:35 PM #7OT:
sir saan ba available yung mga orig 555 parts? any particular shop sa banawe or anywhere in qc.
- Mar 2005
- 1
- Dec 2003
- 546
May 14th, 2005 02:49 PM #9parsectherm.
wrong thread bro.
theres a 10 page thread full of comments about the chevy optra. use na lang ang search function
high idle RPM at engine start
