Results 31 to 40 of 70
November 11th, 2002 07:58 PM #31
Boss Freeman,
I'm too excited to get my suspension upgraded, :shock: is there any chance that I could have it done within this week or next week? :D
November 12th, 2002 11:24 PM #32Originally Posted by pajerokid
Here it is the Patrol's approach x departure x ramp break over angles = 37 x 27 x 31 degrees, wala pong halong daya, kinopya ko lang from my trusty magazine. :D (hirap hanapin lumang model na kasi tong patrol ko, I had to search back last 4 years, hehehe)
- 10,620
November 13th, 2002 10:06 AM #33ako din gusto ko itaas yung strada ko
ok na ako sa 31x10.5xR15
right now naka 255/70/15 with 15x8 na mags
pasok naman may konting sabit sa front fender and bumigat steering
baka pede na yung torsion bar tapos sa front tapos change shackles sa likod?
November 13th, 2002 12:34 PM #34
ungas::: ok naman pla specs ng Patrol :D Kasi sa itsura parang ang haba masyado e :D
kimps::: You got new tires na? congrats! :D pwedeng pwede ang binabalak mo. Get Old Man Emu Springs sa likod :D
- 10,620
November 13th, 2002 12:45 PM #35PK wala pa nasa drawing board pa lahat!
so ok na yan crank the torsion bar then change shackles sa likod
ok lang ba yung hindi na ako mag change ng shocks?
wala naman problem sa likod kaso kapag nag crank ako ng torsion bar, eh ka level na ang likod pang nag load ako sa bed masagwa naka tingala sa langit strada ko
eh kung di na ako mag change ng springs? shackles na lang?
eh kung di na ako mag change ng shackles? springs na lang?
November 13th, 2002 02:43 PM #36Originally Posted by pajerokid
pajerokid::: sir, medyo napansin ko nga parang mababa tignan because of its bubble top and lower driver's view. If you will notice kaya mataas ang break over angle ng safari, intact ang under parts nito from the chassis. :D
Originally Posted by kimpOy
kimpOy::: pwede naman po ma-achieve yung binabalak nyo cranking the torsion bar if the suspension bumps permit, pag 1-2 inch height kaya pa po kahit stock shocks ang gamitin. Mas makakaganda ng porma if you would raise it equally front and rear. Para po di naka tingala yung ride nyo. :D
November 13th, 2002 02:44 PM #37
kim::: tanong ko k mike. wala akong experience sa leaf springs e :|
November 13th, 2002 02:49 PM #38
( Pahabol ) With regards sa leaf springs, madaming options pwedeng gawin to achieve its ideal lift. :D
Pwedeng shackles ang palitan, leaf spring spacers pag leaf over differential ang setting, or change the OEM leaf springs for an aftermarket ones. :D
- 10,620
November 13th, 2002 02:59 PM #39please sir thanks in advance
kasi last night may nakasabay ako sa petron meycauyan naka GEN I strada din kaso naka 31s siya medyo pasimple lang ako tumabi sa kanya!
yung mags ko dati is 15x7 ngayon 15x8 na medyo bumaba yung ratio ng sidewall ko kaya bumama din height ng strada ko!
November 13th, 2002 03:21 PM #40
Kung kasya 32 sa ride mo, wanna get mine? :mrgreen:
6 tires Dunlop Grandtrek AT1 32x11.5x15
yung 2 tires bagong bago kapapalit ko lang last week. Balak ko kasi kunin yung Baja ni Glenn10 :mrgreen:
high idle RPM at engine start
