Results 1 to 9 of 9
- Jan 2006
- 3
January 15th, 2006 10:27 AM #1I have a problem with my shifting pattern. I own a 1995 Isuzu Plaisir Bighorn. My RPM always fluctuates when I'm going over 60. I had it fixed already but the problem is back. What can I do or what should I tell the mechanic when I get it fixed?
Btw, where can I get an original left-hand drive dashboard? Mine was converted from Subic and the dashboard they put in replacement is pangit. (parang minasilya lang).
Thanks.
January 15th, 2006 01:44 PM #2
i think the problem might be in the fuel delivery system. parang may nudge kapag tumatakbo na. mausok ba?
afaik, the plaisir's engine is the 3.0L 4JX1 EFi. same as the local trooper.
the dashboard naman, try mo sa isuzu.
January 15th, 2006 10:08 PM #3
AFAIK, Walco in Banawe has Dashboards. Keep in mind that dashboards are rarely sold as a complete unit. May shell lang, merong may panels, etc. Basta iba ibang levels of completeness.
Or you can also try and get in touch with kimpOy as your Apalit Pampanga tourguide. hehehe. Ito na yata ang alternative career niya. :D
- Dec 2002
- 2,335
January 16th, 2006 02:26 AM #4if its a 95 model then 4JG2 pa engine nyan. but agree ako kay banaweonline mukhang fuel delivery. step by step solution muna. check/replace fuel filter, then injectors.
February 24th, 2006 03:00 AM #5
hi guys..i just change my 4jg2 manual tranny to automatic...and also change the injection pump..ang problem is minsan pag nka 4th gear ka na ang bigla mong inapakan yun accelerator dapat mag downshift sya to 3rd gear, sa akin bumababa sa 2nd gear so biglang hi rev ng engine.. i thing may kinalaman yung auto tranny cable, accelerator cable and sensor...need your help guys...ano po ba tamang setting nito.... tnx
- Mar 2006
- 11
March 6th, 2006 09:00 PM #6Originally Posted by banaweonline
Need help....
May 4th, 2006 12:16 PM #7
- Sep 2005
- 141
May 4th, 2006 08:55 PM #8Bro i was a bit curious dun sa temperature guage nung bighorn ko (honda horizon) kc lage less than or 1/2 yung temperature kaya what i did was bimuli ako nung mechanical guage temperature. Unfortunately it gave me a different temperature reading. Minsan sobra init umaabot ng 200 degrees so that means more than half, pero dun sa digital yung sa instrument panel onte pa before mag 1/2. Kc my uncle owns a bighorn before then on his way to the province biglang umiba yung andar over heat n pla cya pero yung temperature guage nya 1/2 lng.
- Sep 2005
- 141
May 4th, 2006 08:58 PM #9Dunno if compatibility is an issue kc digital yung isa then mechanical din yung isa. Thanks for the advices.
bottomline question for many potential costumers, "is it coding-full, or is it coding-free?"
Geely Okavango
