Results 1 to 18 of 18
    Aug 2010
    Do you know shops that offer truck bed painting service?
    this is not an ordinary paint but something that can withstand heavy load, abrasive resistant and prevent rust. with texture.
    pls. post the contact infos here.
    or is there a DIY kit that can be bought out there?
    brand? price?
    Jan 2013
    Ziebart has
    Oct 2015
    Quote Originally Posted by trucker111 View Post
    brand? price?
    Ride 4x4 in Banawe used to do it. They used a rubberized textured coating on mine. Not many shops offer it anymore because of the drop in ones. I'd still put a drop in on top of the coating to prevent dents and chips. It's also added protection if water proof properties of the spray on are doubtful.
    Oct 2015
    brand? price?
    Aug 2013
    brand? price?
    undercoat yung ginamit sa pickup bed ng sakin.
    3M brand.
    P3000 singil sakin 3 years ago.
    bali spray undercoat tapos paint na black para makintab.
    Quote Originally Posted by Wh1stl3r2 View Post
    The pick-up/SUV accessory shops offer this. Undercoating will suffice but the ones meant for the bed are sprayed on with a thicker coat.
    I remember dati, ingat na ingat ako sa paint ng pick-up bed ko. When i had the coating applied, they scrape off pala the top coat for it to adhere.
    Aug 2010
    how much sa Ride?
    Aug 2010
    how much sa Ride?
    Most of the truck beds now are covered with plastics, mine already has a lot of scratches. Do you recommend to have it painted with 3M rubberized paint and will it stick to the plastic bed cover?
    Oct 2015
    Naalala ko nung ginawa yung akin, nakakangilo panoorin. Para akong ginagamitan ng drill ng dentista. Hehe.
    *trucker111
    Sorry I forgot how much, that was a long time ago. Maybe around 10K-ish?
    The reason I had it done (despite having a drop-in) was because the drop in was scratching the bed on a lot of contact points so much that the bare metal was showing.
    Oct 2015
    *trucker111
    Jan 2016
    Boss, check nyo po ito nakita ko lang sa olx
    Line X
    https://ssl.*******/item/line-x-spray...dbf#945e2b1dbf
    Aug 2010
    meron bang Rhino lining dito?
    Jul 2006
    I have one of those drop-in bed liners. Water gets in between the pick-up bed and the liner when the bed is washed. I have to drive up on a speed hump to let the water drain all out.
    Aug 2010
    kaya raw walang kuenta yang drop in bedliner.
    the moisture will eventually rust the truck bed.
    sa USA, sikat ang line-x for truck bed paint service.
    Jul 2006
    I was googling Rhino Linings locally, and found out that Ziebart sells them.
    The Ziebart website is slow to load nga lang.
    Jun 2017
    Rhino Linings same as ZIEBART SPRAY-On Linings
    Jun 2017
    Does anyone have experience with the ZIEBART SPRAY-ON Liner?
Pickup Truck Bed Paint
