Results 1 to 3 of 3
August 11th, 2003 06:50 PM #1
What improvements can I make to the stock suspension of my Strada to improve handling and stability during stability and cornering?
Thanks.
August 11th, 2003 06:52 PM #2
Remove body lifts to make it more stable? High center of gravity kasi ang design ng Mitsu and Toyotas :D
August 11th, 2003 08:23 PM #3
IMO lang, if may body lift the center of gravity is the same as long as the tires are same sizes. the body is lifted but the under chassis clearance is still the same, so there will be no difference. i read about this sa design ng london double decker bus even na its tall and narrow it is not really prone to turn turtle because of the low center of gravity. unless siguro mga race car speeds and cornering speed.
if you want more stable driving, change to aftermarket shocks of good quality, change anti-sway bar bushings to poly's, put weight sa rear to eliminate bounce.
Xiaomi E-Car
