Results 611 to 620 of 867
- Apr 2007
- 14
May 23rd, 2007 09:23 PM #611
May 23rd, 2007 09:26 PM #612
*jayvee wala na yung dati ? nice ride ahh i like the color pero mejo patay yung color ng gulong mo :D upgrade na yan sir :D .
pwede siguro i pa shave ng konti ung lip ng magz mo para contrast cya :D
- May 2007
- 20
May 23rd, 2007 10:43 PM #613thanks for the response... appreciate it... is the 540T offer a good buy?? budget wise mahal pa ang dmax nagyon. what do you think?
- 10,620
May 23rd, 2007 11:50 PM #615
May 24th, 2007 06:46 AM #616
mga sir , kung maglalagay ba ako ng pang off road na tires mga ilang inches na lift ang kelangan ko ?
eto current height ng pickup ko
current na nakalagay na tires eh r15 60series 205 , parang gsto ko na kasi mag pataas ng pickup any suggestions ?
May 24th, 2007 07:22 AM #617
Lowrider:
What size of tires are you thinking of? The most I was able to put on my L200 before was 225/70/r16. From stock height, I put in rubber coil spacers for the lift up front.
You really wont be able to put in larger tires used in SUVs and 4x4 pickup with the suspension height you have...unless you perform a body lift.
HTH
May 24th, 2007 07:24 AM #618
May 24th, 2007 08:40 AM #619
*djerms
ganon ba sir , when you say bodylift ano yung mga papalitan ? and gaano kaya to kamahal ? worth it naman cguro to no sir ?
May 24th, 2007 08:57 AM #620
A body lift is basically adding spacers between the frame and the chassis. Its ideal if you want to put in larger tires than allowed in stock height. Suspension is not tampered with so the ground clearance from your frame remains the same.
It depends on how much lift you want. Im not sure of the cost but some body lifts involves extending the brake lines, moving the radiator, extending the shifter, etc.
Kung minor body lift lang, the mods I mentioned might not apply.
WOrth it if you really want to put in the larger tires but putting in larger tires means that you might have to re-gear, brakes might have to be upgraded, and engine might have to be tweaked.
HTH
Xiaomi E-Car
