Results 111 to 120 of 134
November 6th, 2004 03:12 AM #111
sir ungas thanks very much for the info and pics. kayang kaya ko na DIY yan.
November 6th, 2004 09:45 AM #112
noticed na ang rubber seal sa likod ng head lights wala na. hindi ba nag fafog ang lights mo? we return it even HID ang bulbs binubutas and put some silicone.
November 6th, 2004 11:39 AM #113
I removed the rubber grommet that should be there in the first place. Maliit yung butas, kahit na pinalakihan ko na, tumatama dun sa red connector papunta sa bulbs. Hindi maganda ang fit, meron electrical discharge palabas, delikado baka may tamaang pyesa yung kuryente.
Nope, kahit na malakas ang ulan or river crossing trails di naman foggy yung lens assembly. But I did put silicone sealant around the adapter kit and bulb just to be sure.
PROMDIBOY::: Good luck! Madaling lang yan, you will need the right tools for the right job. :D
November 7th, 2004 02:41 AM #114
arb where do you install the ballast pag sa gen 2 pajero? sa driver side kasi medyo masikip dahil sa coolant reservoir?
November 9th, 2004 02:32 AM #115
sir ungas na diy ko na, madali lang pala. pero without your instructions dagdag pa iisipin ko.
medyo napapaisip ako kung talagang orig ba yung hid ko. kasi walang philips na branding yung bulb. pero ballast meron. meron ba yung sayo?
my kit sorta looks like this, this is the pic from the seller in ebay. my box is just an ordinary cardboard box without print. the plastic casing of my bulbs doesnt have anything on it. thats why medyo napapaisip ako kung fake.
November 9th, 2004 02:23 PM #116
Yup ganyan din halos yung packaging ko nung dumating. Bulbs are not maunufactured by Philips, Ballasts lang ang ginagawa nila for Hella and other brands too.
Buti nga maganda pa yung bulb casing mo. Yung sa akin ordinary round caps, akala ko lalagyan ng bottle feeds ng babies. :D
Napansin ko nagbago na pala design ng ballasts nila. Itutok mo pababa nga pala yung exhaust ng ballast (the balck small vent inbetween wires), just incase biglang mabasa ng tubig ang engine bay, di papasok sa loob agad.
November 9th, 2004 10:10 PM #117
not sure lang kung saan nailagay one day lang kasi at sinoli ulit yung lights less than 24 hours nakakabit.
November 9th, 2004 10:49 PM #118
question po... does this mean na kailangan HID kit mismo ang ilalagay instead na HID bulbs lang? nalilito po ako..
November 10th, 2004 02:15 AM #119
knicks, hid kit includes bulbs and ballasts.
sir ungas nadagdagan lang ng waterpoof plastic cover and butas pang screw sa sides. Buti namention mo yung tungkol sa butas, meron kasi nakalagay sa instruction na hindi ko maintindihan. "please drill a 23 m/m hole in cental of the original waterproof cover. " wala akong binutas sa ballast, did you do this?
I was able to find a good spot for the ballast. sa loob ng fenders, nasa taas lang siya ng wheel well. wala siya sa engine bay and well shielded. I followed the same position in your pic sideways ko ininstall yung ballast. kailangan ba talaga nasa baba yung butas?
November 10th, 2004 05:17 PM #120Originally posted by knicks1204
PROMDIBOY::: Yung lumang ballast meron nang sadyang butas para sa vent holes. Di ko na binutasan. Mas makakabuti na pong pailalim yung butas, lalo na ikinabit nyo sa fenders, di maiiwasang matalsikan ng tubig.
Normal po Yan saken inde bababa need pa re start everybody can share same as my experience so I...
high idle RPM at engine start
