Results 31 to 34 of 34
August 23rd, 2004 03:03 AM #31Originally posted by wrcastro_ph
Bro,
Di ba parang me problema ang Isuzu dyan braking on wet roads? yung byenan ko kasi naaksidente last week nag skid din ang likuran (Isuzu Fuego 2003 model). Then nawalan na ng control, tapos binagga na nya yung sasakyang naka park sa gilid .. then umikot sya... hayun ... wasak yung harap ng Fuego. Pero before this.... skidding happens thrice already. Yung Goodyear rubber kaya ang culprit dito or the vehicle itself? We are planning to replace the stock tires maski makapal pa ang rubber just to avoid the same accident. Ano sa palagay nyo?
Usually 'yong skid na na-experience ko is pag basa ang kalsada. I used to drive a Corolla, before I had my XUVi, and I had to make a lot of adjustments on my driving style. After 2-3 months driving the XUVi, nagkakilala na kami. By the way even on dry pavement roads, the Micheline LTX will skid when you slam on the break even you're only at a speed of 60kph. Will probably switch into a new set of tire brand. Am thinking of a Pirelli Scorpion.
- Nov 2002
- 35
August 23rd, 2004 03:35 AM #32Di lang skid nag-360 degrees spin din ako sa SLEX naman. From Cabuyao to Sta. rosa, susubukan ko lang sana kung aabot ako 200kph sa corolla gli ko.
It was midnight so konti lang sasakyan (mostly trucks). Pag pasok pa lang ng express hataw agad kasi nga hanggang Sta.rosa exit lang ang target ko. I was doing 180 kph (yun yung huli kong nakita sa gauge bago nag-spin yung kotse) sa fast lane nang may 10 wheeler truck na nag-swerve sa lane ko. Biglang preno ako pero di kakayanin kaya kabig ako sa right.
Yun na! nag-skid na yung kotse, kinabig ko sa kaliwa (to counter steer) pero sumobra kaya pakabila naman ang spin ng kotse. Wala na akong magawa kaya todo apak na lang sa preno at hinihintay ko na lang tumigil. Sabay lang speed nung truck at nung kotse ko na nag-sspin! Tumigil lang yung pag-ikot nung nahulog na yung kotse sa shoulder lapit na bumangga sa puno tapos naiwan na ako nung truck.
That was July 15, 2003 midnight (natandaan ko date kasi anniv namin ni misis hehehe).
August 23rd, 2004 04:21 AM #33
Vermicelli..kaya ang itinalagang maximum speed sa ating expressway eh 100 kph lang. Buti na lang wala nang ibang masamang nangyari sayo.
- Nov 2002
- 35
August 23rd, 2004 04:58 AM #34Kiper...masuwerte pa rin ako dahil upod na goma lang inabot ko. I've learned my lesson.... not to brake and turn at the same time kung walang ABS hehehe jk lang. Di ko na ulit gagawin yon.
high idle RPM at engine start
