if you are on a super tight budget and your Vehicle is not brand new. then you can do it yourself...
buy a surplus intercooler...
the only hard thing doing this by yourself is finding the right hose curves. since you can't bend these hoses because it affects pressure...
as long as you know the intercooler will fit. mounting it shoudn't be much problem. just look for a welding guru outhere... (just prioritize the hose position first before welding it with brackets and screws...)
if the intercooler stock fan is taking much space, remove it and replace it with a thin fan to mount in intercooler and connect it in the electrical line where it will turn on before ignition...
surplus intercooler without fan= 1500-2000
thinest fan= 800-1200
Hose=150-500 (or better ask the spare hose from the intercooler)
total cost more or less 3k + free fun and headaches experience...
and no guarantee it will maintain boost response or cause more Lags instead...
