Page 1 of 2 12 LastLast
Results 1 to 20 of 28
    Oct 2003
    Is there a way to install a manual cutoff switch for a Pajero Bubble side fieldmaster? May phobia na ako sa carnap ( lost a Galant VR )and I remember installing a cutoff switch with my old (1980s)cars thru power supply of ignition coil. How about diesel engine? Someone advise me to install the switch at the fuel pump. Is that safe and possible? At least added protection and to delay the carnapper a bit. I dont trust the factory alarm most probably memorize na ng carnapper yon. Thanks
    levi, welcome to tsikot
    yes there's a way, and you've answered it,
    hide a switch that goes to the ignition,
    if your pajero uses an electric fuel pump... you can attach the switch there.
    Just look for the starter wire, cut it and put a switch in between. I'm not sure about putting a fuel pump cutoff on a diesel. I don't even know kung electric ang fuel pump ng mga ito since I could take out the key in my old Benz and it still would not die.
    my sentra 2 had a switch on the fuel pump. Turning off the pump would let the engine idle for about 10-15 seconds until the fuel in the lines to be used up. If you step on the gas, the engine dies right away.
    yes you can since electric shut off ang pajero.
    Electric ba yun? Buti na lang pala nakauwi ako nung nagloko alternator at nag-flat ang battery ko.
    san ba pwede magpalagay ng switch??
    cost??
    Wreckless, gawin mo na lang sa bahay mo. Ang gastos mo lang ay yung switch, wires at electrical tape. Si sir garyq marunong ata gumamit ng tester para malaman kung aling wire ang lalagyan ng switch.
    Oct 2003
    OK thanks. I want to be sure before doing it and baka may iba pang option. Im planning to hide the switch at the back of the center console. Malabo ng maisip ng carnapper yon and I can easily switch it. Im planning to install connectors so if I have any problem with the switch, i can easily return it to the original connection. Wala bang effect kung humaba ang wire? Since Im installing a switch, the signal will go first to the switch inside then return again to the engine compartment. Thanks
    Kimpoy,
    From PinoyDVD?
    madali naman maglagay ng switch e..
    san ko nga lang ilalagay??
    (well anyway pwede ko naman tanong sa tito ko..
    mapagawa nga yun one of these days.)
    Dec 2002
    yung manual cutoff ng Euro 1 Field Master ko ay sa computer box ikinabait. yung switch na inilagay ay manipis pa kaysa toothpick kaya mahirap talagang hanapin at saka yung wiring eh ipinadaan talaga sa ilalim ng carpet. kung maaari ay ikaw lang talaga ang nakakaalam kun saan nakalagay yung switch. mahirap din magtiwala sa mekaniko kung hindi mo talaga kilala.
    yung sa akin libre lang ang pakabit duon sa kaibigan ng anak kong mekaniko sa Antipolo. switch lang at electric wire angbinili nya. ;)
    You can also buy OEM switches ang put them in plain sight on the the instrument panel. The thief won't think that they're for the ignition kill.
    (e.g. OEM Pajero foglamp switches usually found on the opposite side of the hazard switch).
    naku lagot kayo sa anak nyo di na secret ngayon yan hehehehe.. Pero pinakita na sakin ni Jojo dati yan
    welcome levi ikaw po ba yung sa pinoy dvd?
    dun mo na lang lagyan sa may starter yung maliit na wire dun. just like otep said.
    para nde ma start parang dead na battery.
    Mar 2003
    fierari,
    kaw din pala yung Big Red Machine sa pdvd?
    Jul 2003
    sa pajero ang linya isang wire lang to the fuel pump yata. sa patrols, 2 linya yan (rotary type injection pump) isa green yung rubber boot. isa yung pula. yung pula yung masmataas nakamount. kapag di nakakabit yun, di aandar.
    Levi,
    yup im kimpoy from pdvd,
    pedeng ilagay ang switch kahit saan basta ba mahaba ang wire,
    yung sa friend ko nasa glove box pa nga then lock niya niya glove box.
    Originally posted by hens
    fierari,
    ndi fierari din gamit ko sa pdvd heheh
    bakit si boybi at meowpao (dieseler) lang nakikita ko lagi dun pati pala si kimpoy hehe ano handle mo dun ser hens?
    kasi sa chit chat ako lagi eh
    ayoko na tumingin sa audio stuffs kasi ayoko na mag up grade he..he
Manual Cutoff Switch
