Results 21 to 40 of 54
    #21
    Kung city driving lang, hindi maganda i-match ang gas type sa leaf springs. Matagtag lalo ang kalalabasan ng project (AUVs have ligher body). Better stick with liquid shocks. Lifting properties ang kailangan, that means you should add length na hindi kukulangin at hindi rin sosobra.
    Sa Terrano naman meron nang aftermarket springs/shocks yan. Just be ready with the budget. Parang plug and play. :D
    #22
    right now fluid type yun likod ko so dapat change ko ng liquid match ba ito sa sa leaf spring?
    thanks mr president......
    #23
    Yun pala ibig kong sabihin, fluid type shocks, sorry. May iniisip kasi akong ibang liquid particles nung sinusulat ko kanina.
    Jan 2003
    #24
    meron bang fluid type KYB Shocks? so it means better ang fluid kaysa sa gas type on all occassions?
    #25
    I didn't specifically post that fluid type shocks are better on any given situation. There are some setups that need only fluid types and there other setups that need to use gas type.
    Jun 2004
    #26
    if your looking for a softer ride go for fluid shock. but with the bad roads here in the philippines i would recommend you stick to gas shock only if your considering KYB or Tokico. My experience the fluids don't last long dahil sa sama ng mga kalye natin (potholes/butas).
    #27
    ayun naman pala so di na ko gagastos sa fluid unless short na sya after lifting 1inc. or 1.75inc.
    #28
    Nope, try mo muna sa OE shocks kung uubra naman makakatipid ka na. Pero nung naglift ako dati sa Tamaraw FX namin dati, yung 1" inch lift tukod na agad yung OE shocks nun. Di ko lang sigurado kung mas mahaba ang play ng OE shocks ng Crosswind models.
    #29
    sige sir post ko na lang after installation.............thanks a lot sa info.........
    Aug 2003
    #30
    xwind oks na ba lifting mo? pix naman
    #31
    i hope today ma pa install ko
    ito yun pic ng palalagay ko
    #32
    Paalala lang baka magkabaliktad yung pag lagay ng shackles. Meron ibabaw at ilalim yan. :D
    #33
    huhuhu paano kaya yun alin kaya dito sa pic na to ang tama intall....
    #34
    or this...........
    #35
    or this...
    #36
    Last posted pic, para madali mag adjust ng butas.
    #37
    or like this...
    #38
    Sundan mo kung paano yung orig configuration ng bolts.
    #39
    yun pala yun pwede rin ba dun sa taas yun mas marami butas para in case na mahaba sa taas sya nakatago.
    #40
    Wow ganyan din sana gagawin ko sa GEN1 ko last time kulang lang ako sa Oras.. naka bili na ko ng shackle.. diba mura lang yan?? wala pa yata 200 pesos isang set??
    Mahirap lang mag hanap ng longer Bolts na kakasya at saka parang tapered yata yung sa Gen 1
    PAKI POST LANG NG PICTURES PARA MAY IDEA DIN AKO..
lifting rears via hanger
