Results 31 to 37 of 37
October 26th, 2006 08:59 AM #31
October 26th, 2006 09:03 AM #32
Dati meron ako Gen2 Strada parang tanda ko spring over differential na ito o mali lang ako ng tanda?
October 26th, 2006 04:06 PM #33
November 15th, 2006 10:05 AM #34
November 15th, 2006 07:18 PM #35
note- if you change to SPOA you will need at least minimum 4" of lift for the front. And why do you want to change the rear suspension configuration? it has the best ride among pick-ups in its generation. I think you need better shocks to make it less bouncy, too soft suspension and crappy original shocks results in unbalanced damping.
November 16th, 2006 03:02 AM #36
well, I'm actually opting for a suspension lift. I'm asking for options. Besides, one leaf from my set already broke...again...thanks for the info sir. For sure, if I'm going to change the leaf set, definitely I'd be changing the shocks. Balak ko sana parang setup ni Sir Woodfire dati. Bilsteins up front then OME at the back...but then it would take some more time, since i'd be getting the suspension lift up front... :D
BANNED BANNED BANNED
- 3,790
November 16th, 2006 08:03 AM #37another I notice the fuego series ride softer than the dmax...the fuego have very long lift springs (length wise)....may be this is also a factor to have softer ride.
I have loaded my frontier before the 750kg, lundo na ang likod. Naka tingala na ang harap...mahirap idrive ng ganun (mahina grip the front tires) ... nagiging malikot.
Sa dmax nakapagload nako ng 600kg without signs na observed sa frontier... I don't think that the 150kg difference would affect it...pero my dmax was a 2004...baka ito yung mataas ang payload capacity. And I haven't had the time to check the number of lift springs on the 3 different dmax that the office have.
Xiaomi E-Car
