Guys ask ko lang ano mas maliwanag...
GE H4 170/130 watts o yung
Catz/Philips H4 Hi/lo HID KIT?
Plan ko kasi bumili sa states but of course i want your opinion on this..
thanks
thanks
Catz/Philips H4 Hi/lo HID KIT <<<=== nothing beats the HID when it comes to lighting. :D
Plus HIDs only consume 35W of power from its source. Not like halogens which counts by the hundreds.
ganun ba okie thanks. =) I plan to upgrade kasi its either i put auxillary lighting or HID na ako. Pag auxillary kasi di ko alam san pwede ilagay coz wala namang bullbar yung trooper ko.
mdpo::: subukan mong mag drive infront of ungas, then you will see the light...
I nominate ungas as our Lighting GURU (LG), hindi po collins ah. Ano say mo OTEP?
mdpo::: Kulang pa yung standard driving lights sa ilalim ng bumper nyo? If you are going to buy an HID kit, better check the bulb that is included in the package. Imo, I would recommend the D2S bulb with an H4 adapter with hi-low solenoid switch. The old H4 design which the bulb moves itself is a product recall. There are instances that the ceramic holing the bulb gets cracked like the first globes I got. Good thing autolamps had it covered by its warranty and changed them with the D2S and an H4 adapter.
afrasay::: Boss Vic!!! :mrgreen: Si KCboy po ang hari pag dating sa mga ilaw.
ungas,
di ko ata na gets yun ah... i am planning to get catz kasi yung sa catz may h4 adapter din. What u mean yung bulb ang gumagalaw??? di ata na gets??? :lol:
btw mali pala yung title ko baligtad yung t and h hehehe
ungas: meron na ako kinabit sa ilalim ng bumper kaso kulang parin heheh medyo madilim ata yung tint ko hehehe :wink:
Yung first generation HID bulbs which is an H4 bulb set puro mga product recall. Kasi po yung ceramic holding the glass bulb may tendency magcrack under rigorous vibrations. Kasi pag gumana yung bright-dim function labas-pasok yung galaw ng first batch HID bulb. Kung naalala nyo bumili ako sa autolamps online dati ng 4300K Hylow kit. Binalik ko ito sa kanila kasi nasira yung ceramic thing na kumakapit sa HID glass bulb. Pinalitan na nila yung unang binili ko and they sent me an original HID bulb which is D2S type. then sinamahan nila ng H4 attachment which controls the hi-low beam (a wing type solenoid controlled for bright-dim function). Though the hi-beam is not that helpful not like the bright functions on halogen types. Wala kasing depthness yung HID bright function. Broad light lang focus ng hi-beam ng HID. Maliwanag at nakakatulong lang pag titingin kayo ng road signs and exit points sa expressways but not 500 meters away from lenses.
Sinubukan ko naman mag bright ng HID on dim-litted rural hi-ways, hindi ko makita yung ilaw ko sa daan. Not like halogen type bulbs, pag nag bright ka malinaw yung daan 500 meters beyond your hood line.
Ungas so u mean wag nalang ako mag hylow? yung low beam nalang? panu pag bright function... hmmm parang gusto ko mag ipf nalang na H4 ah hehehe =) di ko lang kasi alam san ikakabit sa trooper. D2s yun ba yung may cover na bakal to remove the glare? swing type? dati sa autolamps ang pinakikita is yung lumalabas pasok na function ngayon pano na yung cover ang imiikot?
alfred,
si ungas nga ang hari ng ilaw sa offroaders. talo na yung mga ilaw ng pajero ko sa HID nya.....
ungas,
KING of LIGHTS!!!!!!!!
Mas maganda naman ang hylow, binago nga lang ng autolamps ang design nila sa bulbs. Luma yung labas pasok ang bulb, nasisira agad yung ceramic na humahawak sa bulb. Yung bagong labas nila may bright function din but not that helpful sa palayuan ng buga ng ilaw pagdating sa halogens. (Mas malayo po kasi ang naabot ng bright foglights ni KCboy nung nagkasabay kami :D )Originally Posted by mdpo
Yung sinasabi nyong cover sa unang labas ng hylow kits yan, yung D2S bulbs walang cover unless specified kung anong adapter light na kakabitan tsaka lang magkakaroon ng chrome cover sa harap ng bulb. And the cover is not there to remove any glare. It simply acts as a reflector to bounce back the light emitted by the bulb to the H4 housing reflector.
Yung bagong cover ng HID hylow kit hindi na labas pasok ang bulb nya. the bulbe is steady as mounted. Then yung adapter kit nya ang may function sa pag swing out ng wings for bright mode, closed wing for dim mode.
Ilaw mo nga hinihiram ko nun sa highway pag hindi kaya ng bright mode ko, hehehe. Ibig sabihin ganun kalakas yung mga foglights mong nakakabit. Kahit na nasa likod kita nun, ang lakas at layo ng inaabot ng ilaw mo. :DOriginally Posted by KCboy
KCboy: ano po yung foglights niyo? sa isa long ride gamit ko IPF H4 ok naman siya maliwanag havent tried it sa malayuan though.
Ungas: thanks for the info. come to think of it parang gusto ko nalang magkabit ng IPF H4 hehehe =) kaso wala ako makitang pwede kabitan sa trooper ko...not unless may bullbar ako
Guys,
Sino dito may trooper na may kinabit na driving lights??? hehehe yung bilog =)
I have yet to try the HID foglight design. Kaso the only problem with those are the PRICES! 70K for a pair of HID foglights. 8O
I'm still hoping that the RMDL240 by Lightforce Halogen type will suffice the light I need.
try mo yung ipf ok sya! tried it and so far i am very satisfied except that the beam pattern is not that wide.
mdpo::: You might have purchased the spot beam pattern/pencil cut beam or with small diameter housing, kaya po hindi wide yung beam nya.
IPF has made its name same as with Hella products. I have tried a pair of IPF 900 before. I don't like is the housing; too bulky for me and shakes terribly with its heavy metal housing, imo. Also did tried Hella 3000 series and has the same downside with IPFs.
Now, I'm gonna experiment on Lightforce Blitz RMDL240 series. It boasts the widest diameter available on market and reaches 800++ meters. It has plastic resin housing and lenses which would not vibrate vigorously while lighted (as they have claimed).
i purchased ipf 900 h4 so may hi and lo beam ako. So far i dont see any vibration or shaking with the beam... hmm di kaya galing sa bullbar yung shaking? hehhe :mrgreen:i purchased ipf 900 h4 so may hi and lo beam ako. So far i dont see any vibration or shaking with the beam... hmm di kaya galing sa bullbar yung shaking? hehhe :mrgreen:
I did tried them on before mounted on a steel bumper. Even how many times we tried to remedy the shakes can't be eliminated.![]()
aahh gud na u have tried them so which is better or brighter? hid or ipf h4? btw di ba yung hid naman maski di ka nag hi beam malayo naman ang bato ng beam pattern nya diba? u just wont be able to see the signs that is mounted high above siguro. Kung meron ka sana kuha ng hi and lo hehehe para may idea ako =)
Preferred ko parin hid kasi at least di na ako mamomoblema san ko ikakabit =)
