im planning to put a turbo on my stock 93 l200 , would that be ok ? kasi i dont know if i can trust the people in banawe eh sabi ni ok daw pero di ako sigurado i hope you guys can help me.
non-turbo engines can be turboed, but it's better to start instead by getting a stock turbo engine.
pero you could contact fusion r and autoplus and they'll give you options for this. hth.
ic thnx for the info i just got confused eh i read some threads , btw would a normal tachometer work for a diesel engine ? or meron bang special na kind of tach na para sa diesel lang ?
iba ata yung pinagkukunan nila ng signal for the tach compared to a gas one.
anyway, a guru i am not, so let's wait for their replies. busy ata with the new year stuff eh. :D
mas ok if you get the same kind gamit sa strada 4x4 turbo.. L200 sa iyo? kabit and forget na.
dba iba ang compression ratio and pistons ng Turbo sa non-turbo?
sabi sa'min di daw bolt on ang Turbo sa N/A na 4d56...is that true?
*garyq , kung sa injection pump can i still use ung normal na tach na nabibili sa banawe ?
As far as I know the internals of a 4d56NA and a 4d56TD engines are different. You can install a turbo onto a 4d56NA but you may run the risk of "blowing" up the engine fairly quickly.
You can istall a tach. It's just a matter of knowing where to tap for a signal.
Most 4d56 vehicles have tachs. Adventures, Stradas, Pajeros, etc. I'm just not sure where they pick up the signal.
ic , thnx for the info everyone i think i wont be installing a turbo , maybe il just buy those gas saving devices , and change the ratio of my differential . idont want to risk my engine eh. :D
since you did say you don't wanna risk your engine...
...don't install those gas-saving devices. there is a lengthy thread about 'em here as well.
