Results 1 to 8 of 8
October 26th, 2006 09:43 PM #1
i have been thinking of doing this kasi parang mas maraming 5 holes na mag wheelz na available sa market na mura kesa sa pang 6 holes ? so tanong ko lang if anyone has tried doing this ? or ako pa lang nagbabalak :D is it safe kaya ? anyway i wana know your opinions fellow tsikoteers :D
October 27th, 2006 03:24 AM #2
bro if I were you hwag mo na alng palitan, mas better kung 6 holes compared sa 5 holes
October 27th, 2006 09:29 AM #3
I've heard of these kinds of installations. Some were even from 4 holes to 5 holes. What they do is they fabricate an adaptor to fit and bolt on to your 6 holes on one side, which then has 5 studs on the other. I think offset might be a problem with it tho.
- Sep 2006
- 46
October 27th, 2006 12:22 PM #4ok lang kung 100 to 114 or 114 to 100 or 5 studs euro to japanese 5 studs. delikado yan bro.
October 27th, 2006 09:31 PM #6
What car, by the way? If it's not used for heavy work, it might be okay.
But the problem with offest on a hub adapter might mean your choice of mags will still be limited due to the increase in hub offset.
October 29th, 2006 10:56 PM #8
Ah. Andami namang 6-holes na choices doon na fit sa L200... added gastos lang ang hub conversion, konting tiyaga lang siguro sa paghanap.
high idle RPM at engine start
