Since your axle drops when you do a suspension lift, just fabricate a bracket that lifts the LSPV back up where it previously was before the lift.
sir otep, panu ko po malalaman na un na po ung LSPV?somehow siguro pareho ang underchasis ng delica at pajero.
It's the one on top of the rear diff with a spring on it.
You will have to measure the spring length before lifting the vehicle. Kung lifted na nakuha, just estimate 80% of the actual lift height. Mahirap pag sumobra ang bracket, you risk locking your rear tires first when slamming on the brakes.
umm...kasi, i replaced the rear shackle....e kung sukatin ko nalang nga ung distance from approximate center ng "+0inch" hole to the "+2inch" approximate center hole-->it may be not really 2 inches,e.., then multiply ko ng 80%, siguro ok na un,di ba?
math formula: (distance from +0 inch to +2 inch) x 80% = height ng bracket?
tama kaya ito?para isang tabasan lang, ok na.....pero pwede na din tanchahan,di ba?
thanx po.
