Results 21 to 26 of 26
July 7th, 2005 10:46 PM #21
Since your axle drops when you do a suspension lift, just fabricate a bracket that lifts the LSPV back up where it previously was before the lift.
July 7th, 2005 10:50 PM #22
sir otep, panu ko po malalaman na un na po ung LSPV?somehow siguro pareho ang underchasis ng delica at pajero.
July 7th, 2005 10:55 PM #23
It's the one on top of the rear diff with a spring on it.
July 8th, 2005 12:53 AM #25
You will have to measure the spring length before lifting the vehicle. Kung lifted na nakuha, just estimate 80% of the actual lift height. Mahirap pag sumobra ang bracket, you risk locking your rear tires first when slamming on the brakes.
July 8th, 2005 01:41 PM #26
umm...kasi, i replaced the rear shackle....e kung sukatin ko nalang nga ung distance from approximate center ng "+0inch" hole to the "+2inch" approximate center hole-->it may be not really 2 inches,e.., then multiply ko ng 80%, siguro ok na un,di ba?
math formula: (distance from +0 inch to +2 inch) x 80% = height ng bracket?
tama kaya ito?para isang tabasan lang, ok na.....pero pwede na din tanchahan,di ba?
thanx po.
