Results 21 to 26 of 26
Tsikot Member Rank 4
- Oct 2004
- 2,315
December 3rd, 2004 01:38 PM #21gusto ko yun simple lang, yun chromesupertracker o yun modular ng AWC. Ayus mura lang pala yun hehe. Sige po magtatanong tanong po ako try ko muna sa cubao yun malapit sa amin. Tignan ko din sa blummentrit para pwede ko compare.
December 3rd, 2004 05:41 PM #23
If you're going for the looks..then by all means.
Just consider the disadvantages like, speed, acceleration, center of gravity and comfortness of the ride. I don't think it is a bad idea to make your 4x2 look 4x4. Its a matter of preference. Just remember.....Form follows function.
December 5th, 2004 12:34 PM #24
well, from how I understand autos, the body lift will only be useful if you are going to put in bigger tires for better articulation especially if your wheel wells are not that big.
- Oct 2004
- 2,315
December 5th, 2004 09:35 PM #26liit po ang wheel well ko kaya i've decided torsion na ko malapit na tapos bodylift na try ko muna ang lift ng torsion lift and hangers
high idle RPM at engine start
