Results 1 to 10 of 36
- 267
December 17th, 2002 01:15 AM #1saan kaya nanggagaling yung clunk sound tuwing nagkakambio ako pag release ng clutch? check ko na yung universal joints mukang ok naman. :? thanks!
BANNED BANNED BANNED
- 3,790
December 17th, 2002 06:19 AM #2Sir otomatic,
Sa dami ng klase ng sasakyang na drive (puro hand-me-down ng company) ko nuon (which are mostly luma) ang tanging origin ng "clunking sound" problem ko ay iyun lang din X-joints ng differential propeller and culprit. There was this occassion na pagginalaw mo ng kamay lang ang propeller ay mukahang normal lang ang play pero when we replaced it nawala na ang problem ng clunking sound.
Ewan ko lang kung ang pressure plate ng clutch would have the same sound???
My 2 cents.
December 17th, 2002 09:50 AM #3
otomatic:::Check the crossjoint. Correct si wildthing. Try revving the engine madidinig mo din parang may bakal na kumakalansin. Kung sa diff. yan parang "thud" ang madidinig mo. Kamusta na??!! Si boy2 dami ng bang chicks? :mrgreen:
December 17th, 2002 10:09 AM #4
Sir Freddy, meron po bang grease tip yung crossjoints nyo or is it the sealed type?
- 267
December 17th, 2002 10:36 AM #5wildthing & afrasay,
ilang beses ko ng nacheck yung x-joints ng nakababa, wala naman slack.
pero i-check ko pa ulit sana x-joint na nga.
di kaya me welding sa propeller shaft na gustong bumigay o me crack? :idea: meron na kayong naexperience na ganun :?:
im suspecting my differential, sa mga likong sarado at paakyat tumutunog ang tire ko na parang nagpepreno as if ayaw nyang mag pivot. normal ba sa LSD differential yung ganon?
afrasay,
wala pa ba tayong pictures sa pinatubo? hehe. :D panay kasi kantiyaw sakin ni boy2!! :evil: wag muna! istorbo sa pag chi-chicks ang pag-aaral!! :wink:
- 267
December 17th, 2002 10:47 AM #6Originally Posted by Ungas
me grease tip o fitting naman pareho at sagana naman sa grasa.
December 17th, 2002 11:26 AM #7
Did you try to check kung may bingot yung propeller shaft? Baka po di na balanced propeller nyo kaya may saltik sa pag ikot?
December 18th, 2002 10:52 AM #8
I just came from the underside of my car. Looks like my rear universal joint needs replacing. i pulled on my propeller, then pushed, parang meron 'tug' sa sound.... haaay. Pa-replace ko tomorrow. Sabi sa akin this is easily replaced..... dont know how expensive the part is though :D
December 18th, 2002 02:44 PM #9
Armand, kapapalit ko lang ng cross joint kahapon dito sa San Fernando, La Union. pina check ko sa Caltex yung ilalim ng paje ko dahil may sound tulad nung problema ni otomatic. yun nga, ang lakas ng kalog ng universal joint sa front. bale 380php(yung mikaniko na pinabili ko) yung replacement parts plus 180php yung labor. di ko alam kung magkano padding nung mikaniko sa resibo. :mrgreen:
December 18th, 2002 03:08 PM #10
happiman::: Thanks for the info sir Larry! Its not that expensive naman pala :D
Hyundai Santa Fe GLS 2024
Tsikot Hyundai Registry
