Results 1 to 13 of 13
    im planning to put a turbo on my stock 93 l200 , would that be ok ? kasi i dont know if i can trust the people in banawe eh sabi ni ok daw pero di ako sigurado i hope you guys can help me.
    non-turbo engines can be turboed, but it's better to start instead by getting a stock turbo engine.
    pero you could contact fusion r and autoplus and they'll give you options for this. hth.
    ic thnx for the info i just got confused eh i read some threads , btw would a normal tachometer work for a diesel engine ? or meron bang special na kind of tach na para sa diesel lang ?
    iba ata yung pinagkukunan nila ng signal for the tach compared to a gas one.
    anyway, a guru i am not, so let's wait for their replies. busy ata with the new year stuff eh. :D
    yes thanx :D sana may magreply pang iba i really need guidance eh :D
    Aug 2005
    mas ok if you get the same kind gamit sa strada 4x4 turbo.. L200 sa iyo? kabit and forget na.
  7. #7
    AFAIK, sa injection pump kuha ng rpm for diesel engines
    Oct 2005
    dba iba ang compression ratio and pistons ng Turbo sa non-turbo?
    sabi sa'min di daw bolt on ang Turbo sa N/A na 4d56...is that true?
    *garyq , kung sa injection pump can i still use ung normal na tach na nabibili sa banawe ?
    Jun 2004
    As far as I know the internals of a 4d56NA and a 4d56TD engines are different. You can install a turbo onto a 4d56NA but you may run the risk of "blowing" up the engine fairly quickly.
    You can istall a tach. It's just a matter of knowing where to tap for a signal.
    Most 4d56 vehicles have tachs. Adventures, Stradas, Pajeros, etc. I'm just not sure where they pick up the signal.
    ic , thnx for the info everyone i think i wont be installing a turbo , maybe il just buy those gas saving devices , and change the ratio of my differential . idont want to risk my engine eh. :D
    since you did say you don't wanna risk your engine...
    ...don't install those gas-saving devices. there is a lengthy thread about 'em here as well.
turbo for my stock 93 4d56 good or bad?
