Results 31 to 35 of 35
May 31st, 2004 06:57 PM #31
Had my rear drums refaced again this afternoonat the same machine shop that initially did it para wala na added gastos pa. They admitted may konti pa natirang uneveness. Just makes me wonder why they didn't detect it during the first time. Anyway, everythings smooth now. Will continue to observe it. Thanks guys for all your inputs.
May 31st, 2004 06:59 PM #32
pajerokid: Opted to have them re-refaced nalang kasi ang mahal ng rear brake drum para sa Vitara. P5240 original. Wala pang replacement. Huhuhu. Imagine spending more than P10k just to replace both.
May 31st, 2004 07:07 PM #33Originally posted by wiretap_md
Just came from Bigberts. Vincent was very gracious enough as to allow me use of their lifter. My friend Alan who owns a Vitara also was there to do servicing din. Had my Zuk lifted then I had the rear tires spinned. Felt the vibration so definitely the cause was from the rear drivetrain. Palit kami brake drums with my friend. I installed his drums in mine then test drive. Ayun! Nawala ang vibra. Install ko din brake drums ko sa kanya. Sus...nag vibra din brake pedal niya. Conclusion: Warped rear brake drums.
My next move: either to get a new set of rear brake drums or ibalik ko yung drums where I had it refaced before and have it done again.
Mike, Have you checked your Propeller Drive Shaft or Cross joints? Lift your car and inspect by turning your rear wheels. The Propeller should be straight and free from dent or clinging dirt or undercoating paints.
May 31st, 2004 07:28 PM #34
since you guys mention it, i use our vitara today, mdyo feel nga yung surface ng rotors sa pedal pero acceptable naman, di ba ganon sa lahat ng vehicles?
May 31st, 2004 08:40 PM #35
"Acceptable" is a relative term and very subjective depending on the driver's feel. I am particular with the vibration because it is noticeable pero a bit lang (rate ko 2-3/10). I'm sure OTEP would bash me again for being oc-oc. Hahaha. One thing that was driving me was that I was curious as to what was causing it. I'm glad I finally did. I wasn't ready to spend another P10k for drums kasi baka ma warp lang sa next offroad so might as well stick to my old ones and reface nalang ulit since I paid for the refacing already anyway.
Xiaomi E-Car
