Results 1 to 7 of 7
- Nov 2002
- 123
April 28th, 2003 10:42 AM #1Automatic Transmission Fluid. Hindi ko makita sa manual eh. Private use lang ride ko. Thanks!
Tsikot Member Rank 3
- Dec 2002
- 636
April 29th, 2003 02:01 AM #2Under severe use, like MM driving, i'd suggest changing ATF at 30k km or less. I change at 20k km and already see a difference in color- from bright red to reddish brown.
- Nov 2002
- 123
April 29th, 2003 10:21 AM #3Magkano kaya palit ng ATF sa casa? Meron bang mga mapagpipilian nito gaya ng engine oil?
- Dec 2002
- 636
April 29th, 2003 11:11 PM #5Changing ATF in trans is simpler than changing engine oil. Just drain thru drain plug on the A/T oil pan, add ATF thru dipstick fill hole. Usually 3L will suffice, but check level while idling.
So many brands in different grades- there's dexron 2 or 3, Mercon. Find out what grade is recommended by your car's manufacturer.
Try Mobil ATF or Mobil 1 ATF- both dex 3.
April 30th, 2003 08:36 PM #6
The owners manual of our cars usually put it at 40K... with bad road conditions and the weather we have (rains, humidity, etc), its probably better to change every 20-30K more or less depending on the drivng conditions you encounter.
Pag nalubog din yung car mo sa baha, its also nice to change after the rains just to be sure na walang water contamination.
Tsikot Member Rank 4
- Jan 2003
- 2,979
May 2nd, 2003 12:37 AM #7how do you know kung palitin na atf? paano ba ang proper na pag-check ng atf?
Xiaomi E-Car
