If your trooper has 7in wide rims then 265/70R16 is the max width you can use safely but this will also increase rolling radius by 14mm or 28mm overall diameter so taller gearing and the speedo will be off by about 8% only.
Ungas: tnx for your comments. Galing!
Mauler: kala ko kasi 17 inch yung rims mo.
jackaroo: oo nga no. DI ko na consider yun but I think I can live with that. T.Y mga friends! Now I just need 20K):
sir ungas
yung scorpion at ba ramdam mo talaga yung tagatag? and kamusta ang tread wear? soft or hard compound ba siya? kaya ba ng 275/70r16 sa 16x7 rim?
medyo malapit nain kasi ako magpalit, mukhang scorpion na choice ko kasi walang bfg available, then wala daw atang yoko na pang 16?
jackaroo parang mahal ata prices diba mas mahal ang pirelli sa yoko? bili ni boybi 5400 sa sonny ok for 265/75r16.
gusto ko talaga wider tires 275/70r16. saan mo nalaman na max size na 265?
sir ungas and jackaroo. ano pipiliin mo fo pajero? yoko or pirelli? need expert advise nadadala kasi ako sa brand name ng pirelli. thanks
Don't be lured by the brand itself, they may claim their prestige in sedans but not in the bigger vehicle segments. I would go for road grip ability that the brand names.
Meron BFG AT sa Ryco, 245/75R16, Php 5580. Yung 265/75 6,440. WITHOUT MOUNTING/BALANCING.
Kimpoy Yokohama Geolander actually nakakabit sa akin ngayon. How much yung 265 nung and saan ako pwede magtanong ng price? THANKS!
Originally posted by kimpOy tested ko na ang yoko, i'll vouched for that tire.
same as sir kimps, tested ko na rin ang Yoko Geolandar A/T +2 and I'm very much satisfied with these tires. Unang-una na napansin ko nang magpalit ko ng tires(from Dueler H/T), laking improvement sa ride comfort. Hindi siya matalbog o matagtag. Noise? Mas tahimik pa siya doon sa dating H/T tires ko. Durability? I've already run 10k using these tires and no noticeable thread wear. Parang bago pa nga. IMO, alaga lang sa alignment baka tumagal ito ng more than 50k. Traction? Wet and Dry, superb ang traction niya. I never heard these tires squeak. Offroad? Tried them sa soft sand w/out engaging in 4WD, they bite pretty well ( syempre, with so much sand splashing). Looks? Agressive. Para siyang mild na M/T. On the downside, medyo mahina ang brakes.
Purchased my Geo's(31x10.5x15) at Princess Tire Supply located at 2304 T. Mapua St. cor Laguna St. Tel# 254-1904. Ask for Tom. Price is P4350*.
promdi: meron bfg na 265/75R16. 6.6K!!!AT tyre yun. Walang balancing/mounting and pick up sa Makati lang. Check if this is the new model na AT KO. Im not sure. Paki post results.
MT's are mud terrains, medyo iba ang orientation dito sir gary,
muds are morea t home at... muds siyempre, so compromise yung riding comfort, medyo maingay sa daan and longer braking distance, now kung seasonal off roader ka stick to All terrains,
but if you live kung saan maraming putik and lahar go with muds.
MT's are generally expensive than AT's
but sometimes some dealers would like to get rid of their slow moving mud tires for a low price.
Kung 70%-30% onroad-offroad ratio ang gamit ng sasakyan, better get an All Terrain rubber. Now, if the ratio is 50:50 mild mud tread patttern would be more suited. As boss [b]kimpOy[/] mentioned, this will be more expensive than all terrains. Price range is around 6K-8K per tire. Kung deeper lugs and extreme mud tires like Simex and Mickey Thompsons, 10k-20k per tire.
Kimps and Ungas: Thanks for the enlightenment! I see the light! It's now between BFG 245/75R16 AT(Php 5580) or Yokohama Geolander AT2 265/70R16( Php 5650)
