sir just want to have a piece of advice in buying a used pick up will be use in carrying load what are the reliable and durable unit available in the market,many thanks to all
For your budget, it is favorable to go with Mitsubishi L200. With its ever reliable 4D56 engine, hindi ka magsisisi. Also, the parts are easy to find and affordable. Marami ding mekaniko ang may alam sa makina nito.
thank u sir dale,how bout isuzu fuego?i dont have any background in pick up
sir what would be the problem regarding flooded diesel vehicle?like pick up
The problem with flooded diesels is not with the engine, but with the electrics (power locks, power windows, wiring/relays, and horn).
May I suggest that you look for the Nissan Frontier 4X2 1998-2001, the good thing is they still make it today as the "Nissan Bravado 2.7", same body, and the same engine so parts would be plentiful.![]()
Your choice for an Isuzu is the best for me. Bullet proof engine reliability (timing GEAR) coupled with great fuel economy is your best bet for a good workhorse.
Second choice for me would be the immortal Toyota Hi-Lux. Prices for 2nd hand units may be pricey but worth it in the long run.
Diesel engines like the ones mentioned above wouldn't have much problems when flooded except if water enters the engine via the air intakes but other than that it would be fine.
my :twocents:
2003 4x2 Fuego owner here.
It was also bought 2nd hand few years back with 40,000 in the odometer at P500,000 (already lifted with 265/70/15 tires).
Pros:
-easy and relatively cheap maintenance.
-good fuel economy.
-very reliable engine (4JA1 with turbo).
Cons:
-noisy engine.
-rattling noise in the cabin.
Its a good work pick-up.
You will probably settle for a pre-2000 model at your 250K budget. Not to worry since all Fuegos basically look the same.
sir thank you sa mga info.learn a lot from it,i was choosing between isuzu fuego and nissan ultra eagle,ive heard that they are both using a timing gear?so der wil be no incident that snap a timing belt,and they are both direct injection,what wud be the parts that i must to see before buying a used pick up?thanks a lot sir
How about MAZDA BT 50 . I seen they use it for drifting with a turbo charged engine.
if i were you, id go with any nissan Eagle series, i have a nissan eagle BD25.the fuel consumption is good and the engine is strong, no major problems with its engine, the only problem i cant stand is the stiffness of the suspension but it runs very well,
I suggest you go for a Nissan Frontier...
Based from personal experience:
We have a 2000 Nissan Frontier 2.7 4x2 bought brand-new
Pros:
Strong engine (4x4s are 3.0)
Stable
Strong chassis
Aircon
Front seats
cheap parts
it's a Nissan
Cons:
Suspension is stiff
Rear seats
-we have had no problems. for real.
You know, GMA and ABSCBN both use this for their fleets. Useful for extreme terrain and different environment.
The condition depends mostly on the user.
thank you sir,i have an eye for this isuzu fuego fuego LS 2003 model,they say that isuzu is much noisier and cabin really vibrate but for the engine its one tough engine so il go for isuzu fuego,does anyone know the price range of this isuzu fuego ls 2003 model,the seller want it for 400k,how much will i negotiate for its thanks a lot sir for all your response,mabuhay
Mga sirs dudugtong lang ako sa topic na to. I'm planning also to buy a 2nd hand pick-up. What can you say about the ford ranger? Yung around 2003-2004 model. Thanks
Fellow tsikoteers, I just want to ask kung san meron reliable shop in Bulcan area that modifies manual window to power window, especially for Mazda B2200 pick up. At kung magkano kung sakali ang magagastos? Pati alarm at central lock. Thanks.
sir any feedbacks on 1994 Nissan sunny Pickup?
ok ba ito sir? magkano pa market value? good buy ba ito or iba na lang?
Sir i huv a l200 pickup w/ 18s lorinser mags, sparco seats, newly paint gray, bnew cristal headlights, new sidings, for 240k neg....http://cdn.sulitstatic.com/images/2011/1216/090126524_08560514866a233c2cf402585898174d5927022d c28761a28.jpg
