Results 21 to 40 of 54
    #21
    palit tayo... pajero ko.. sa patrol mo... haha.. para magawa mo yung mod.. hehehe jk
    #22
    sige, kung gen3 yan, payag ako :;
    Signature
    Dec 2003
    #23
    Mga sir. Same procedure din ba sa strada gen2? Nasa ibabaw ang wastegate. Parang ang tigas nung nakaconnect na rod at parang magbebend ang wastegate housing nung itry ko. ano principle nito?
    #24
    PK
    Thanks sa Pictures now gawin ko din yan pag uwi ko... tingnan ko kung bibilis pa Pajero ko... hataw na naman sa SLEX hehehehe... di kaya sumabog engine ko non
    #25
    TFR,
    Same engine tayo. Matigas talaga yan. hehehehe. Konting brute force ang kailangan. Matigas kasi ang spring sa loob.
    #26
    pajerhoy, 3 washers per bolt po, so six pieces in total. three pairs.
    tfr, otep: with the 4D56, i disconnected the rod before removing the can. brute force will then be applied only on reassembly.
    nightrock, dati pa yung washer trick sa 4D56T. Kayod ka kasi ng kayod diyan sa abroad e! hehe
    dudes, i observed better shifting from the AT. Unlike before, ang hilig mag downshift kapag moderately floored yung engine. Now I get the wanted acceleration at lower RPMs, but im sure this mod is better felt by people who have stick shifts.
    #27
    interesting! have you heard of any ill effects long-term with the added boost?
    i assume your ECU maps and fuel systems are all still stock?
    #28
    Nah. Otep, KC and a lot of other guys with Mitsu Turbo Diesels have this mod with no side-effects BTW, were all using mechanical fuel injection. No EFI involved.
    #29
    :cool: that's good.
    #30
    Yup, gotta love these old school engines. hehehehe.
    #31
    sir pk... nalilito ako.. 3 ba tlga or 4? hehe...
    Mar 2003
    #32
    sir pk will this affect our fuel consumption?
    #33
    hehehe galing ni PKid....kala ko nagbabasa ako nang manual nang pajero...
    Jan 2003
    #34
    yeah!! I'm off to the hardware store!!! thanks PK! hahahaha :devil:
    #35
    Sir PK,
    Galing mo talaga sa pajero.
    I will try to do it and see the difference, went to baguio on the holy week tingin ko i need the extra boosts.
    Wala ba itong negative effects on the turbo? Or engine?
    You mentioned using 20mm long #12 Grade 7 sa 4m40.
    What will i use for 4d56? I plan to try it out muna sa gen2 namin since bago palit yun turbo and kulang yun boost.
    Thanks a lot and more info!!!
    #36
    Just bring your OEM bolts to the hardware and specify the next longer one. Ganun lang ginawa ko. hehehehe.
    #37
    Si PK tulog na ...sobra dami kinain sa Congo Grill kanina har har har :D
    #38
    TIP.
    mighty bond the washers para hindi hassle, konting drops lang naman para madali din mabunot.
    ayos yang washer tip na yan, i remember doing 140kph sa Govic highway sa zambales with OTEP and tebs
    #39
    Sir OTEP,
    Do you have pics of your actuator? Nakita ko na yun can pero hindi ko alam paano ilagay yun washers. PICS naman
    TY
    #40
    nandun sa lumang how to crank up the 4d56 thread.
    nasa taas lang yun.
4M40 + Washers = :) :) :) :)
