Results 1 to 10 of 224
    Quote Originally Posted by beebs
    you can use either 265/50/20 or 295/45/20. both have the same dia with your stock tire (265/70/16). if you'll use the 295/50/20 tire, you'll increase your tire diameter by 29.5mm..
    beebs, what about sa ride ko na Sorento.Tire size is 245/70/16 kung 20" din na rim ang gagamitin, which tire size kaya will fit? What about the ride, will it bumpy pagkatapos? Will it be okay kung gagamitin ko sa rough roads? Saka last na tanong beebs, the price. Thanks!
    Jul 2005
    Quote Originally Posted by jeanpierre
    you can use 245/50/20. lalaki lang ng 3.6 mm ang diameter mo which is negligible. your ride will still be the same as long as you don't exceed 30 psi. as for durability, 20" tires usually have high tensile strength ratings since it's designed for SUVs. di nga lang siya for extreme off road use pero kung mga dirt roads with gravel, ok lang. as for the price, 20" rims will cost you from 25k to 70k per set. tires, 50k to 70k per set.
    beebs, thanks for the very interesting info. May kailangan pa bang mga spacers o adjuster to fit this size of tires sa Sorento? Saan ba magandang bumili nito? Pasensya na, ni lubos-lubos ko na ang tanong
    Jul 2005
    sa tingin ko di na kailangan ng spacers. may mga alam akong dealers ng mags and tires, may terms pa ako, he he. post ka pag decided ka na magpalit, tanong ko rin friend ko re best mags for sorento.
    Thanks beebs. I'll post you pag na sort out ko na yong budget ko para dyan.
20" mags
