Results 1 to 6 of 6
- Nov 2003
- 89
December 26th, 2003 03:19 PM #1Guys! tanong ko lang would there be a bad effect on the engine kung worn-out na ang insulation ng spark plug cable mo? Napansin ko kc na matagal ng worn-out yung 1 wire pero wala naman ako napapansin na kakaiba sa makina ko. i have been experiencing irratic idling pero sabi ng mech baka raw kc marumi na injectors ng kotse ko. an when i use fuel injector cleaners medyo nawawala at bihira na bumalik. what do you think?
Tsikot Member Rank 5
- Nov 2003
- 3,849
December 26th, 2003 06:33 PM #2worn out insulation can cause the current to jump or be erratic in its delivery to the spark plug . try to replace your hight tension wires as this is probably the cause of the weird idling you're experiencing. in case ganun parin idling mo, at least you've solved the problem with the high tension wires =)
- Nov 2003
- 3,849
December 29th, 2003 12:27 PM #4OEM may be more expensive than replacement/performance wires. canvass ka nalang to see what's within your budget
- Nov 2003
- 89
December 30th, 2003 09:24 PM #5tanx guys! ok rin ba replacement wires lang i mean tatagal naman kya sya or baka more expensive in the long run kc palit ulit agad?
- Nov 2003
- 3,849
January 3rd, 2004 10:24 AM #6they should last the same amount of time naman i doubt they will be inferior in any way to the original ones. be careful lang of the brand you get
the hybrid corolla cross looks more appealing at those prices.
Mitsubishi Xforce
