Hi mga sirs:
After starting my car in the morning, it wont run, even if I press the gas and in other case will turn OFF. but after 5 minutes after I start engine (idle) it will run na po. Ano po kaya ang problem? My car is Toyota Corolla 91. TIA
Hi mga sirs:
if you have a manual choke pull it out half-way to up you rpm to 1000rpm. this would shorten you warming up period.
check mo ignition system. open-type ba sya?(meaning, nabubuksan), carbs might be fouled. check mo din kung ok pa yung mga spark plug wires- spark plug din. fuel system din baka di na ok ang fuel pump.
ah before baka may tama na ang ignition coil mo. nag overheat siya pag mainit na.
yup kaya pinalitan... pero kaninang umaga I try to start it... then ayaw.. then try again... then nag start naman... then I turn it OFF. I check the baka me natanggal, pero wl naman... then I touch the ignition coil... ang init as in di mo mahawakan sa init.
dami pl dapat ikonsider pag ganon... pero pag cold start lang... after n uminit... ok n po... after start puede n itakbo agad basta mainit p engine.
