Results 1 to 10 of 11
- Sep 2006
- 13
November 9th, 2006 09:44 AM #1Hi mga sirs:
After starting my car in the morning, it wont run, even if I press the gas and in other case will turn OFF. but after 5 minutes after I start engine (idle) it will run na po. Ano po kaya ang problem? My car is Toyota Corolla 91. TIA
November 9th, 2006 10:00 AM #3
if you have a manual choke pull it out half-way to up you rpm to 1000rpm. this would shorten you warming up period.
November 9th, 2006 10:01 AM #4
check mo ignition system. open-type ba sya?(meaning, nabubuksan), carbs might be fouled. check mo din kung ok pa yung mga spark plug wires- spark plug din. fuel system din baka di na ok ang fuel pump.
- Sep 2006
- 13
November 9th, 2006 10:05 AM #5dami pl dapat ikonsider pag ganon... pero pag cold start lang... after n uminit... ok n po... after start puede n itakbo agad basta mainit p engine.
- Sep 2006
- 13
November 9th, 2006 10:34 AM #6
November 9th, 2006 10:49 AM #7
ah before baka may tama na ang ignition coil mo. nag overheat siya pag mainit na.
- Sep 2006
- 13
November 9th, 2006 10:55 AM #8yup kaya pinalitan... pero kaninang umaga I try to start it... then ayaw.. then try again... then nag start naman... then I turn it OFF. I check the baka me natanggal, pero wl naman... then I touch the ignition coil... ang init as in di mo mahawakan sa init.
November 9th, 2006 08:20 PM #9
dapat yun coil nahahawakan mo, well kayang hawakan. pag sobrang init it is going bad na. di ba surplus lang pinalit?
- Sep 2006
- 13
November 11th, 2006 11:24 PM #10
