Results 1 to 10 of 13
July 10th, 2006 06:09 PM #1
im in need of a Toyota Corolla AE101 Wiring Diagram.. or manual.. mukhang sira ang wiring ng park lights ko.. kasama ang dash.. tried to change the fuse.. kaso sinunog e.. tried to reinforce the fuse with wire para direct contact kaso may ibang nasunog naman sa ilalim ng steering wheel.. ngayon everytime na i-start ang tsikot e may tumutunog na parang relay na ewan sa ilalim ng dash.. ano tingin niyo? a wiring diagram would definitely help..
tingin ko may short e.. kaso di ko lang alam kung saan..
July 11th, 2006 12:15 AM #2
Fully Booked Greenhills Promenade sells service manuals for various vehicles including Corollas. Even rare cars like Land Rovers meron sila. Aroun Php1,500++ per manual. May wiring diagram yun.
July 11th, 2006 12:43 AM #4
Yung sa GQ sa National Bookstore ko nabili, eh. Hindi ko napansin if may GU. Pajero meron. Pati Volvo 850 at LC70 series.
July 11th, 2006 03:42 PM #5
hmmm.. e kung downloadable na service manuals? i found some pero walang pang Corolla na AE101 e..
BANNED BANNED BANNED
- 3,790
July 11th, 2006 03:54 PM #6you probably burned the relay too...shorted ang line ng park light mo. NEVER bypass a fuse next time. It was made to prevent burn-outs.
I am a wiring diagram (hanes manual) of an AE101 but EFI model ito. I'm not sure if this would work. Maraming pages contains the wiring diagram (unlike the old toyota's), i'm trying to locate the parking light portions and the dash wiring.
July 11th, 2006 04:03 PM #7
yehey!! all AE101's naman yata have the same wiring e.. basta same body type..
well.. lesson learned the hard way.. i always do bypass kasi the fuse of the Stereo Line.. lagi nagbu-bust ang fuse kaya hayun made it permanent na.. kaya i assumed it would somehow work for the park lights too.. for the meantime hanggang makauwi lang..Last edited by Marc MD; July 11th, 2006 at 04:08 PM.
- 3,790
July 11th, 2006 04:45 PM #8AE101 is the bigbody right?
here are the topics (1997 models and up ang notes nito): (which one do you need)
- Starting, charging and ignition system wiring diagram - 1 page
- Engine control system wiring diagram - 2 pages
- Electronically-controlled transaxle systems wiring diagram - 1 page
- Daytime Running Light (DRL) system wiring diagram - 1 page
- Headlight system wiring diagram - 1 page
- Back-up and stoplight wiring diagram - 1 page
- Tail light system wiring diagram - 1 page
- Rear window defogger and interior light system wiring diagram - 1 page
- Turn signal, hazard warning and horn system wiring diagram - 1 page
- Automatic light and seat bealt warning system wiring diagram - 1 page
- Shift lock and airbag system wiring diagram - 1 page
- Power window system wiring diagram - 1 page
- Wiper and washer system wiring diagram - 1 page
- Electric mirror and sun roof system wiring diagram - 1 page
- Power door lock system wiring diagram (with anti-theft) - 2 pages
- Anti-lock Brake system (ABS) wiring diagram - 1 page
- Cruise control system wiring diagram - 1 page
- Cigarette lighter, clock and audio system wiring diagram - 1 page
- Instrument cluster system wiring diagram - 1 page
- 1.8L engine ignition system wiring diagram - 1 page
- Radiator cooling fan and A/C system wiring diagram - 1 page
- Overall wiring diagram - 23 pages
...whew....
July 12th, 2006 12:22 PM #9
wow! comprehensive!! i think i need:
and maybe the:
soft copy ba yan? or hard copy? Haynes yata has eBooks na din e..
thanks!!!
- 3,790
July 12th, 2006 03:27 PM #10hard copy, i'll scan 'em and post or email it to you if you want....give me an hour...slow scanner ko eh. Photocopy yung orig ko actually - which I got cheap from a GT member/forumer
Yes kasi adjusted na nila yun binayaran mo initially to reflect yun correct plate ending mo, that's...
1st LTO renewal after 3 yr registration
