Results 1 to 10 of 14
June 30th, 2004 03:04 PM #1
My wiper speed isn't that "perky" nor fast anymore. If I rate it siguro 0-10 with 0 being no movement and 10 being performance like brand new, mga 7 nalang siguro. New pa naman blades ko and bagong windshield detail from Bigberts. It looks like weak yung wiper motor. Ano kailangan kaya nito? Relay? Cleaning? Or replace motor brushes? Any shop that specializes in wiper motor troubleshooting? Thanks guys!
FrankDrebin GuestJune 30th, 2004 03:10 PM #2
Got a same problem with our L200. Bagong windshield detailed din Big Berts wala pa rin pero gumanda ang pag-wipe pero mabagal pa rin. New NWB wipers and a cheaper P160 wipers wala pa rin. Tinaas ko yung wiper ok naman ang pag-andar. Sabi nila sa bushing daw ng wiper. Hindi ko nga lang alam kung saan ipapagawa.
June 30th, 2004 04:40 PM #3
bushings din ng motor ang problema ko, dinala ko sa servitek west ave., di ata nila kaya tirahin dun, wla paraw silang experience magpalit ng bushings, matagal daw kasi yun!
sabi naman ni master ungas, kaya daw yun ng mga banawe boys, - ang hirap lang takot ako dun....
any shops na recommended ng mga naka experience na ng ganito?
BANNED BANNED BANNED
- 3,790
June 30th, 2004 08:49 PM #6pedeng relay and bushing problem. kailangan niyong kalasin para makita ang "play" sa bushing and kung relay, irekta lang sa battery ang nasa isip ko to check if may change of speed sa direktang contact.
wala yatang nagagawa nyan specifically - i would DIY it if I were you.
June 30th, 2004 08:51 PM #7
Wild, where exactly are these bushings located? Are these the bushings sa linkages or bushings inside the wiper motor itself?
- 3,790
June 30th, 2004 09:19 PM #8meron bushing sa motor (just like the electric fan motors) usually made in copper - may play na ang motor spindle. meron din bushing sa arm, usually plastic and metal...like a ball-and-socket configuration (parang shoulder ng tao). Pag iyun plastic ang ang nasira, palit ang buong arm assembly. Depende sa configuration .... mazda na pick-up kasi ang ride ku nuon na nasira....plastic ang problem...awa ng diyos meron nabibili na replacement assembly ng arm.
FrankDrebin Guest
Be careful with channels like "China Observer" on YouTube. There is a clear bias in their posts and...
Xiaomi E-Car
