Results 11 to 20 of 27
- 54,293
- Nov 2009
- 3,509
May 11th, 2018 12:14 AM #2Tap water will do for most bugs and dirt.
If you are lucky tailgated a Japayuki bus spewing oil from behind then your windshield is drenched with oil and its raining hard at pit dark evening on a 2-way national hiway, brake and parts cleaner and plenty of tissue/ newspaper will be very helpful.
This happened to me resulting to zero visibility and glare from the oil, good thing i always bring brake cleaner and tissue/newspaper, and luckily a spare wiper blade re-fill since it is due for replacement also.
May 11th, 2018 12:26 AM #3
Di pwede sa everest ang nawasa juice nagi-skip ang wiper. I use the blue concentrate from handyman, forgot the brand. But since i started using it wala na yung judder ng wiper. 1 liter bottle makes 10 liters of mixed fluid.
- Aug 2017
- 321
May 11th, 2018 09:10 AM #4
- Jan 2018
- 844
May 11th, 2018 09:32 AM #5
- Jan 2015
- 714
May 11th, 2018 06:21 PM #7
May 11th, 2018 10:54 PM #8
- May 2018
- 2
- 54,293
May 24th, 2018 09:15 AM #10the blade refill?
sa mall auto accessories stores, po. i SM.
the complete assembly is more expensive than just the rubber blade. price range is large.
if complete assembly, one should know the size length. measure yours, or bring it for comparison.
for the rubber blade only, they are sold in pairs of one long length only. we cut it to fit our vehicle. also, there are two blade or spine size diameters. if you buy the wrong one, you will have to modify your blade holder using long nose pliers. it's not impossible, "just a little difficult".
also, one has to know how to remove the outgoing blade.
and for some reason, some stores place them behind other items. either you ask the salesperson, or you look behind the items yourself.
the first time replacement of blade is attempted, it is difficult. the subsequent ones are just like replacing a ballpen refill.
some post-ers mentioned buying theirs from the casa.
i have no experience with this.
Yung extra AUX Fan is useful sa mga naka montero. Mag improve daw yung AC system since may extra...
