Results 1 to 10 of 13
November 15th, 2007 02:44 PM #1
ask ko lang kung may problema na ba sa engine or normal lang ang paglabas ng puting usok sa tambutso.... ano kaya ang symptoms nito or yung maaaring maging problema later?: wonder:
November 15th, 2007 02:56 PM #2
Afaik, no problem yung white smoke unless it is dark.
There is a thread about that topic bro. Search mo lang.
- Nov 2007
- 65
November 15th, 2007 03:03 PM #3depende s puting usok kung marame hehe
lalo n pag mainit n ung makina
baka blow by n makina mo
November 15th, 2007 03:12 PM #4
Thanks, mga bossing! worried lang kasi ako kasi di naman dating ganun ang car.
November 15th, 2007 10:28 PM #5
kapag sa cold start at may white smoke nothing to worry, sabi pa nga nila na this is a sign of a very healthy engine pero kapag uminit na makina ay dapat wala ng usok.. at one more thing kapag malamig ang panahon or umuulan normal lang din ang white smoke
November 24th, 2007 12:05 PM #6
white smoke with little water na lumalabas is normal at pag malamig ang engine malalaman mu kung may katok ang engine kung itim at basa ng langis ung spark plugs mu
November 24th, 2007 12:53 PM #7
Gasoline Engine- White smoke is normal in the morning. Black smoke is abnormal.
Diesel Engine- White smoke is abnormal, early indication for overhauling. Black smoke is normal.
Tsikot Member Rank 5
- Nov 2003
- 3,849
November 25th, 2007 05:58 PM #8smoke at any other time than a cold start is bad on a gas engine. black, white or blue are all warnings of something wrong.
- Jul 2006
- 145
December 7th, 2007 08:03 AM #9Mga sir, yung sa akin eh lumalabas eh manipis na bluish smoke pag nirerev ng malaks, pag naka idle wala naman. Sabi nung isang talyer na pinagtanungan ko, idrain ko daw ang gas tank, then pa gas ng bago...Ang kotse ko po ay bigbody gli 93 model. 2 to 3 times a week ko lang po nagagamit car ko for an ave 15km per gamit. Ksi po nagmumutor po ako malimit ngayon dahil sa mahal ng gas eh.
Please advise naman po dun sa bluish na usok pag nirerev, mga spark plug are tuyo, brownish ang sunog.
Maraming salamat po.
- Nov 2003
- 3,849
December 9th, 2007 08:37 PM #10normally valve seals or piston rings yung cause ng smoke.
try replacing the pcv also.
