Everytime I step on my accelerator pedal, may whining sound ako naririnig. Wala naman akong nararamdamang problem sa makina, un nga lang nakakailang. Ano kaya ito? :x
wirings yan.. baka sa sounds.. dati nun kakasetup ko lng ng sounds.. nagkaganyan ako na prob :mrgreen:
artpogi,
I dont think sa gulong kasi I listen to the engine kapag naka-idle eh.
Odell,
I'll check my wirings pero hindi siya static eh.
Other suspections?![]()
Pwede din pong baka drive belts ninyo ang mga ito. Have their tension checked. Goodluck.![]()
Afrasay,
yep naririnig ko rin kapag tumatakbo pero kapag naka-idling meron din eh..i think sa belt drives nga yata..hintayin ko nalang lumala para sure ako kung san nanggagaling..hehe :mrgreen:
Djerms, napasugod ka ba sa baha recently? kse dati ganun din nangyari sa aking e.... may whining sound kapag tumataas yung rev...
apparently it was a bearing nung pina-check sa casa. hth :mrgreen:
:mrgreen:yep napasugod ako sa maraming baha! So kung bearing po ang problem, what will the mechanic do? just degrease it? How much po kaya and saan ko sya dadalhing shop...aircon? Thanks guys!! :D
Depende kung kumakalog or may play na yung bearing dapat ng palitan. Nakakasira rin kasi ito ng belt. Kung hindi pa, pwede lang sprayan ng wd40 para matanggal yung dumi at kalawang. Ganun din kung sa tensioner ng timing belt kasi bearing din yun.Originally Posted by Djerms
saan mo ba naririnig yung whining sound?
kung sa speaker mo may problem yung mga groundings
Thanks for the tip guys!
OZcity,
I dont think sa wirings kasi naka-off naman usually ang radio ko. Anyway, I'll check on that again. Thanks.
Jun,
Thanks...question lang po...saan located ung bearing na un? :wink:
PK,
Malabong manggagaling sa twin turbo set-up ko kasi....kasi...wala ako nun hehe :mrgreen:
I experienced that "whining" sound for about a month which i thought was normal, not until last saturday when the idler bearing (tensioner) of the compressor belt stuck-up on me causing the drive belt to snap due to friction while in Batangas 8O. I was able to come home though but with a/c off. I had the car serviced at the casa and they just replaced the bearing and the drive belt and no more "whining" sound. :lol:
There is also a possibility yung center bearing connected thru the propeller shaft natuyuan ng grease.
