Results 1 to 10 of 15
- May 2006
- 4
May 26th, 2006 06:17 PM #1magandang hapon po sa inyo mga masters & experts, newbie here and i have some questions lang.
regarding to sa gauge temp ko, i dont know whats wrong with it eh. kasi sa araw normal yung gauge nya almost half sya but pag dating ng gabi sometimes lumalagpas sya sa middle. Pinacheck ko na sya sa autoshops here then ginawa nila nilagyan lang ng ground chord, pero after that ganon pa din sa gabi. pero sabi nila di naman daw overheat kahit lumalagpas sya sa middle.
ano po opinyon nyo dito bakit ganon?
and isa pa 'bout that gauge also, kapag ginagamit ko sya sa long drive kapag speed ko na is 120kph napapansin ko tumataas din temp gauge ko more than half na but kapag nagbawas ako ng speed unti-unti bumababa din sya, stable sya sa middle kapag speed ko is 70kph - 80kph. Pero never pko nag-over heat.
may car nga pala is 95ESI. 2nd owner ako and 4yrs. ko na sya ginagamit.
tnx and more power!
- May 2006
- 78
May 26th, 2006 07:42 PM #2Originally Posted by sad_but_true
May 27th, 2006 01:16 AM #3
Kumusta ang oil mo? Gaano ka kadalas mag-dagdag?
Ang coolant? Gaano kalakas sa coolant?
May 27th, 2006 01:31 AM #4
are you using coolant in your radiator. if not, most probably debris of rust or corrosion is already blocking the coolant passages inside the radiator. coolant or water can no longer circulate corectly during high speed runs. another possible cause is a busted thermostat. have your radiator or thermostat checked.
- May 2006
- 4
May 27th, 2006 09:29 AM #5mga bossing tnx sa replies nyo.
regarding sa mga tanong nyo, ok naman lahat eh, except pala sa oil, may konting leak lang pero konti lang at di naman nababawasan oil ko. regular din ako magpachange oil. Ok din po yung radiator ko, kasi naparepair ko na rin at or napacheck kung may bara. Im using coolant also at pagchinecheck ko yung resevoir ko normal nababawasan din pero konting-konti lang.
im wondrin lng kasi sa temp ko eh, para kasi sya yung nagiging speedometer ko, lolz.
Tsikot Member Rank 5
- Nov 2003
- 3,848
May 27th, 2006 08:23 PM #6your problem is with one of the ground wires in the engine bay. i'm almost sure of it.
- 48
May 28th, 2006 08:28 AM #7have your radiator cleaned first... due time na din for it to have it cleaned... besides, mura lang ang magpalinis ng radiator... unahin muna ang mga cheap moves para makatipid din :D
May 28th, 2006 02:32 PM #8
happened to me before...almost same exac scenario...culprit was the water pump. =)
jagxtrm GuestMay 29th, 2006 10:42 AM #9
pag nag change ka ng water pump, i suggest you also replace the thermostat.
- May 2006
- 4
May 29th, 2006 05:33 PM #10tnx again mga bossing ha, and pasensya na kayo wala ako masyado alam pagdating sa makina ng mga sasakyan.
ask ko lang sana kung ano dapat ipagawa ko sa water pump ko same na din sa thermostat. para at least alam ko kung ano dapat gawin ng mekaniko.
tsaka mahal ba yun? ang hirap kasi din magpagawa ng sasakyan ngayon eh ang bigat sa bulsa.
tia.
Sec. Dizon and RSA seem to have a really good working relationship, btw.
EDSA Rehab/Rebuild and Guadalupe Bridge Repair
