Results 1 to 10 of 18
October 23rd, 2005 09:54 PM #1
what would cause the door handle inside the car to rattle? and how to remedy it?
October 23rd, 2005 10:36 PM #3
Could also be that the steel rods (linkages) have gotten free from their plastic clips. Some foam (or a new clip) will remedy this.
- Jul 2005
- 151
October 24th, 2005 01:41 AM #4maybe because of wear n' tear, how old is ur car?,,looks for the screws and tight it, sometimes there is a little plastic cover u need to remove to see the screws.
October 24th, 2005 08:35 AM #5
After I had my lock repaired at the driver's door, nagkaroon na ng rattle. I have it checked up when I have time. Normally, rattles are caused by loose screws.
BANNED BANNED BANNED
- 3,790
October 24th, 2005 10:06 AM #6yeah baka pagkakasauli ng handles or some parts inside (if not the handle) was not fastened properly.
October 24th, 2005 10:16 AM #7
Yep, most probably some loose screws. Baka kasi hindi yung talagang screws ang ibinalik nung pinagawa. To check, use your screwdriver and try to remove the screws. If there is no resitance, mali yung screws na binalik. Kung mayron namang resitance pero nag-rattle pa rin then yung ginamit nilang screws eh iba ang sukat nug thread. Ang masama dito, baka yung thread dun sa pnagkakabitan eh naiba na yung mga "ngipin" since baka na-pwersea na nung screws na kinabit.
October 24th, 2005 01:33 PM #8
thanks for the prompt response.
consensus seems to be loose screw.
if i am unable to fix this, where would you recommend na paayos ito?
October 24th, 2005 01:36 PM #9
btw, cars are 2 and 5 yrs old (patrol and cefiro). both have rattles at rear passenger side.
October 24th, 2005 02:06 PM #10
Originally Posted by dx8976
Kung dehins, any good enough mechanic would do.
Anyways, you can do this test: remove the handles then drive around your village or street. Kung may nagra-rattle pa, dehins screws yan: malamang ang problem nyan eh yung sinabi ni Boss Otep.
Good luck.
This is a bobo to MMC. Mirage has good sales, sayang benta nila dyan.
Mitsubishi Philippines
