Results 1 to 14 of 14
    any recommended grease or lubricant. when i use wd40, parang sandali lang e. ok b yong ordinary grease (mga 100 petot) o dapat titanium o tgrease ( mga 300+ sa handyman).
    or there is another post in another thread na lithium grease spray??
    one more thing, di ba nakakasira ng paintjob ng hinge yong grease?
    thnx
    imho. you don't want to put grease in there. madumi masyado tsaka pwedeng mag sebo.
    just continue in using WD-40 and spray if necessary or needed.
    Feb 2005
    Quote Originally Posted by junnquinto2006 View Post
    thnx
    I read in other forums the thing to use is silicon grease/lubricant. The type you kinda see in some toys. I think there is a spray type (ala insecticide in a can) with a nozzle to get into the rubbering.
    Dont put a lot and I think they say you need to start near the bottom and towards the top. If you can, open the panel to better lube the railing that holds the windows. This can also be used (or rather should be used) to lubricate the door hinges as well, to prevent rust and that annoying squeaking sound old doors get.
    Oct 2003
    try using singer oil.
    guys, ok ba ang wd-40 for door hinges? hindi ba madumi? yung grease kasi ang dumi (yun ang ginagamit ng toyota casa before).
    As per honda manual White Lithium grease. Im using Optimol white T paste by castrol
    Quote Originally Posted by LoBudget View Post
    yng wd40 ba e siliconlubricant?
    Quote Originally Posted by mazdamazda View Post
    in my case bilis po mag evaporate ng wd40. parang everyday dapat ako maglagay.
    kaya inquire ako wat grease can i use. isip ko kng sa bearing na high temp an heavy ang movement, kaya nya door hinges
    Quote Originally Posted by raine View Post
    where can i buy white lithium grease?
    Although I haven't tried it, marami nagre-recommend ng silicon lubricant, WD-40 brand has a silicon lubricant IIRC, I think I've read it from their website, I'm just not sure kung available sa mga Handyman, TrueValue or Ace.
    I remember I saw a silicon lubricant dun sa malaking automotive store sa Megamall, (can't recall the name), hindi nga lang WD-40 ang brand.
    I'm just finishing off my WD-40 then I'll try a silicon lubricant.
    Aug 2003
    white lithium grease used to be on sale at diy outlets. in the P350 up range afair.
    WD40 is not really a great lubricant. WD stands for water dispersant. It's specialty is dispersing water, not really lubricating. But if you don't mind regularly spraying it on, it'll work.
    For door hinges, grease still works the best. A thin film is usually enough. Some people are a bit overkill and put a whole blob of grease on the hinge. hehehe.
    Aug 2006
    just a thought...
    may nabasa ako somewhere sa mga threads dito that a Tsikoteer applied used synthetic engine oil to lubricate the hinges on his garage gate. come rain or shine, effective daw.
    kaya when we have our 10T KM PMS by next month ay ipinagdadala ko ng container si misis para makakuha ng used synthetic oil when the casa changes the engine oil. then as an experiment, we'll try to apply this around the house, in small amounts, to the hinges ng steel casement windows, house door hinges, hinges ng gates, bike wheels and bearings, etc. tingnan natin kung effective nga. kailangan din i filter muna yung oil through the use of old cotton clothes para mawala yung mga ribaba (metal bits), if meron.
    mas maganda din kung may unused synthetic engine oil para huwag nang i filter. i'll tell my wifey na hingin also yung sobra, kung meron.
    Quote Originally Posted by lolo pepe View Post
    just a thought...
    effective nga, yan ginagamit ko sa kadena, bearing ng bike ko kahit maulanan/mapaliguan ayos pa rin.
recommended grease/lubricant for door hinges
